Date/Time: Fri, 28 Mar 2025 13:12:26 +0000
[Programming Help] - ACSIL custom chart, numbers bars pullback column not showing correctly
View Count: 370
[2022-11-23 18:02:09] |
onnb - Posts: 662 |
When using ACSIL with sc.IsCustomChart = 1 the numbers bars generally show ok (the ask/bid on each price level) but there is an issue with the pullback column In more detail 1. User open a 1 trade chart - this is the underlying chart, each bar is a single trade 2. User then applies a custom chart study which creates the custom chart 3. User then adds the numbers bars study and configures Result - the bid/ask value is posted at each price and is perfect - the pullback column only shows a single row - (could be wrong but it appears its showing the pullback for the underlying chart and not the custom bar) Its strange that the bid/ask on the bar shows correct and the pullback column does not. I can send a screenshot if it helps Date Time Of Last Edit: 2022-11-23 18:02:31
