Date/Time: Fri, 28 Mar 2025 13:24:07 +0000
dom on chart
View Count: 527
[2022-11-22 20:49:55] |
User411320 - Posts: 311 |
Trying to set up my DOM and it's coming out like this all the numbers smeared (photo attached). Please advise
[2022-11-22 22:33:35] |
John - SC Support - Posts: 39009 |
It looks like that is correct, but it does depend on the particular symbol - what is the symbol of the chart? If it is correct, then you need to expand your scale in order to view the data. Right now, it is all compressed together. Refer to the following for how to interact with the scale to expand/compress: Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale There is also an option for Chart >> Chart Settings >> Market Depth >> Combine Increment in Ticks, which will allow you to combine together a group of Market Depth data to be able to see a larger view. Refer to the following: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-23 17:33:12] |
the symbol is NQ
[2022-11-23 17:39:14] |
Here is what we see when we use approximately the same range for the scale. https://www.sierrachart.com/image.php?Image=1669225050744.png As you can see, the numbers are bunched up. You need to expand your scale in order to see the numbers more appropriately. Refer to the information we referenced in our previous post. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
