Date/Time: Tue, 26 Nov 2024 16:20:48 +0000
Missing data
View Count: 987
[2014-05-27 11:55:04] |
sierrartb - Posts: 11 |
Hello, there is a gap in data from 2014-03-25 till 2014-05-12. "Delete and download data" function does not help. http://www.sierrachart.com/image.php?l=1401191403932.png Thank's for help. Richard |
[2014-05-28 07:17:18] |
You are using IB . Therefore, long-term historical Intraday data is unreliable with that service. Update Sierra Chart to the latest release. Historical Intraday data is now downloaded from the Sierra Chart Historical Data service which is much more reliable. Update with Help >> Download Prerelease. After the update, re-download the data following the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
