Date/Time: Fri, 21 Mar 2025 08:19:55 +0000
Market data delay- Denali
View Count: 562
[2022-11-21 11:52:37] |
Fumarate - Posts: 2 |
Hi, Seems like my data is not real-time, it keeps delaying by 3-5 seconds then works properly for a short time and does a similar thing again on repeat. Last week there was no such issue, my internet has not changed, and I am not using VPN. This is a major flaw as can't use the program otherwise... I have sent in a message log from Sierra. Please help as soon as possible. Regards, |
[2022-11-21 12:52:30] |
Sierra_Chart Engineering - Posts: 18875 |
What you see is probably completely normal. Refer to: Prices / Data Falling Behind: 4.10 - Market Not Active Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-21 12:53:14
[2022-11-21 13:59:21] |
I see your point. I am looking at the countdown timer though, I thought it is not affected by that and is just continuous.
