Date/Time: Fri, 28 Feb 2025 01:51:25 +0000
Change text size of working orders on the chart?
View Count: 434
[2022-11-21 01:26:54] |
MeowthTradez - Posts: 44 |
I'm having trouble finding the setting for this. I want to make the working orders that are draggable on the chart to be a bit bigger and easier for me to click on.
[2022-11-21 18:15:15] |
John - SC Support - Posts: 38259 |
The text for the working orders is controlled by the general chart text font. So to change this, you would go to Global Settings >> Graphics Settings - Global >> Fonts and change the Chart Text font to a larger size. Refer to the following: Graphics Settings: Chart Text - (current font name) As you will see, this will affect the rest of the text around the charts. But find what works best for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
