Date/Time: Fri, 21 Mar 2025 07:43:58 +0000
Version Feedback
View Count: 347
[2022-11-21 01:08:32] |
User8135477 - Posts: 133 |
Hello, I just updated to the latest version of Sierra Chart. I am not sure what the general feedback has been like, but I personally prefer the previous layout for changing the chart settings (as well as the original layout for the General Trade Settings, etc.) The font and layout in the original version was much easier to see and navigate, and in fact, it is one of the main reasons why I chose to go stay with Sierra Chart for the past several years rather than switching to other popular platforms. I appreciate all the work that goes on with the software development portion, but I also hope that you take my feedback into consideration. Would you consider either reverting back to the original layout for future versions, or give users the option to select between different layout modes? Thank you. Date Time Of Last Edit: 2022-11-21 01:08:54
[2022-11-21 01:56:45] |
Sierra_Chart Engineering - Posts: 18875 |
, but I also hope that you take my feedback into consideration There is no chance of this.Refer to the information here: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#NewChartSettingsWindow And here: Settings Windows Interface: Introduction The new Settings Windows are highly configurable and you can do what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
