Date/Time: Fri, 21 Mar 2025 10:18:05 +0000
chartbook setup problem
View Count: 452
[2022-11-19 13:02:16]
User787656 - Posts: 1
i am unable to setup g7 foundation chartbook how can i set it up. it shows in massege log that it is not compitable.i need it converted.
attachmentG7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht - Attached On 2022-11-19 12:55:36 UTC - Size: 276.18 KB - 219 views
[2022-11-21 15:07:39]
Sierra_Chart Engineering - Posts: 18875
You really need to contact the provider of this Chartbook and have them update it to the new format. For now follow the instructions here:
Chartbooks (Workspaces): Opening Older Chartbooks
These are the same instructions they need to follow.
Date Time Of Last Edit: 2022-11-21 15:07:59
