Date/Time: Tue, 26 Nov 2024 17:15:08 +0000
Line Tool
View Count: 1081
[2014-05-27 01:05:54] |
wingz - Posts: 121 |
I would like to have one or two additional line tools available to me to draw lines on the charts. I'd like for each line tool to be set to a different color. What is the easiest way to add these to the tool bar please?
[2014-05-27 06:11:42] |
Each drawing tool in Sierra Chart can have up to 8 configurations which can be preconfigured. Therefore, you need to use Drawing Tool Configurations. This is fully documented here along with how to add the buttons to the ToolBar for the different drawing tool configurations: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#UsingMultipleDrawingToolConfigurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-29 05:41:31] |
Thanks. I normally get am email when you respond to questions. I didn't get one on this one. Is it possible that a setting may have gotten changed? Where do I go check to and see if I'm signed up to get the emails when you answer a question?
[2014-05-29 22:07:44] |
The Support Board settings for email notifications are correct for your account. So you are getting email notices, but you are using a road runner email address and they may be filtering the emails. There is not much we can do about this.
