Date/Time: Fri, 21 Mar 2025 08:05:30 +0000
market dept historical graph not showing data for past days
View Count: 377
[2022-11-18 14:20:22]
User988253 - Posts: 21
i watched the webinar yesterday by the bish the pit guy, and have been trying to add historical market dept to my numbers bar chart... i did it exactly how he did in the webinar and that didnt show me past data.. then i googled sierra chart historical data not showing up and went thru hour or so of checking to make sure i had everything done correctly.. NOW i still cant see the colors show up on previous days intraday chart... it only shows up for the most recent day... ive tried for hours now to do this myself and would like some help if you can remote connect to my computer or maybe know what the heck im doing wrong..thanks kyle
[2022-11-18 14:55:09]
John - SC Support - Posts: 38835
First, make sure the data is actually not there and not just at a color level that it is not easily visible (particularly if you use the default colors). The easiest way to do this is to set Show Quantity Numbers to In Bars Only and then set the Use Secondary Numbers Color for Quantities Greater Than or Equal To and enter a value of 1. This will color all the numbers in red (by default), which is typically easy to see.
Once you have this setup, then scroll your chart back to where you are not seeing the data and see if it is really not there.
If it is still not there, then be sure you go through the process to request the historical market depth data by right-clicking on the chart and selecting Download Depth Data From Date-Time. Refer to the instructions here:
Market Depth Historical Graph: Downloading Of Historical Market Depth Data
It can take a few minutes for the data to download. If you still do not see the data then please get us your message log by following these instructions:
[2022-11-18 15:53:34]
i tried all that again.. still not getting anywhere.. here is market log
Created the DTC Protocol server. | 2022-11-18 13:08:30.323
DTC Protocol Server listening on port 11099. | 2022-11-18 13:08:30.324
Reading Internal Order ID file. | 2022-11-18 13:08:30.324
Reading Trade Orders file. | 2022-11-18 13:08:30.350
Reading Trade Positions file. | 2022-11-18 13:08:30.351
Reading Trade Account Data files. | 2022-11-18 13:08:30.351
Software version: 2453 64-bit | 2022-11-18 13:08:30.360
Primary Thread ID: 15820 | 2022-11-18 13:08:30.360
Usage end date: 2023-01-29 | 2022-11-18 13:08:30.360
Enabled for: Advanced Features 2. | 2022-11-18 13:08:30.360
Enabled for: Sierra Chart Historical Data Service. | 2022-11-18 13:08:30.360
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-11-18 13:08:30.360
Enabled for: Delayed Denali Exchange Data Feed. | 2022-11-18 13:08:30.360
Enabled for exchange2: CME (Trading Account Required) | 2022-11-18 13:08:30.360
Enabled for exchange2: CBOT (Trading Account Required) | 2022-11-18 13:08:30.360
Enabled for exchange2: COMEX (Trading Account Required) | 2022-11-18 13:08:30.360
Enabled for exchange2: NYMEX (Trading Account Required) | 2022-11-18 13:08:30.360
Enabled for exchange2: CFE | 2022-11-18 13:08:30.360
Enabled for exchange2: fairx_exchange.data | 2022-11-18 13:08:30.360
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-11-18 13:08:30.360
Current selected Data/Trading service: Teton CME Order Routing | 2022-11-18 13:08:30.360
Custom symbol settings values: disabled | 2022-11-18 13:08:30.360
Chart Update Interval: 500 | 2022-11-18 13:08:30.360
Intraday Data Storage Time Unit: 0 | 2022-11-18 13:08:30.360
Time Zone: +00:00:00 (UTC+00) | 2022-11-18 13:08:30.360
2022-11-18 13:08:30 Local computer time in UTC | 2022-11-18 13:08:30.360
2022-11-18 13:08:30 Local computer time in SC Time Zone | 2022-11-18 13:08:30.360
2022-11-18 13:08:26 Server time in UTC | 2022-11-18 13:08:30.360
Local computer UTC time and Server UTC time difference: 3 seconds. | 2022-11-18 13:08:30.360
Program path: C:\SierraChart\ | 2022-11-18 13:08:30.360
Data Files path: C:\SierraChart\Data\ | 2022-11-18 13:08:30.360
OS Version Number: 10.0 | 2022-11-18 13:08:30.360
Locale Setting: C | 2022-11-18 13:08:30.360
DLLs: UserContributedStudies_64.dll | 2022-11-18 13:08:30.361
Allowed protected custom studies: | 2022-11-18 13:08:30.361
Crash reporter started: true | 2022-11-18 13:08:30.361
Created the DTC Protocol historical data server. | 2022-11-18 13:08:30.361
HD Server Manager | Listening on port 11098. | 2022-11-18 13:08:30.361
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. | 2022-11-18 13:08:30.362
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:08:30.384
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-11-18 13:08:30.523
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-11-18 13:08:30.523
Received 5 login tokens. | 2022-11-18 13:08:30.832
Symbol settings MD5 received. Request ID: 1. | 2022-11-18 13:08:32.152
Symbol settings are up-to-date for sc_futures_direct.dtc.trading. | 2022-11-18 13:08:32.152
Teton CME Order Routing | Firm: Phillip Capital | 2022-11-18 13:08:37.050
Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11089 | 2022-11-18 13:08:37.050
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-11-18 13:08:37.161
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-11-18 13:08:37.161
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-11-18 13:08:37.161
Teton CME Order Routing | Network connection to server complete. | 2022-11-18 13:08:37.209
Teton CME Order Routing | Starting socket receive thread. | 2022-11-18 13:08:37.209
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-11-18 13:08:37.209
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-11-18 13:08:37.341
Teton CME Order Routing | Sending logon request message. | 2022-11-18 13:08:37.341
Teton CME Order Routing | Received logon response. | 2022-11-18 13:08:37.901
Teton CME Order Routing | Server Name: SC DTC Server. Build=43909M. | 2022-11-18 13:08:37.901
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 13:08:37.901
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-11-18 13:08:37.901
Teton CME Order Routing | Trading is supported. | 2022-11-18 13:08:37.901
Teton CME Order Routing | Order cancel and replace is supported. | 2022-11-18 13:08:37.901
Teton CME Order Routing | OCO Orders supported. | 2022-11-18 13:08:37.901
Teton CME Order Routing | Bracket Orders supported. | 2022-11-18 13:08:37.901
Teton CME Order Routing | Connected to server complete. | 2022-11-18 13:08:37.901
Triggering next historical data download in queue. | 2022-11-18 13:08:37.901
Subscribing to symbol for symbol alert. VXH22-CFE | 2022-11-18 13:08:37.901
Mapping VXH22-CFE to VXH22_FUT_CFE. Service code: cfe_exchange.data | 2022-11-18 13:08:37.901
Using symbol data fast lookup vector | 2022-11-18 13:08:37.901
SC Data - All Services | Starting real-time market data updates for: VXH22-CFE (VXH22_FUT_CFE). ID: 1 Service code: cfe_exchange.data | 2022-11-18 13:08:37.901
SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 443 | 2022-11-18 13:08:37.901
DTC Client socket (2) | Creating socket. | 2022-11-18 13:08:37.902
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-11-18 13:08:37.902
DTC Client socket (2) | Connecting to IP: 38.65.8.115. | 2022-11-18 13:08:37.902
SC Data - All Services | Requesting security definition data for: VXH22-CFE (VXH22_FUT_CFE). ID: 1 | 2022-11-18 13:08:37.902
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-11-18 13:08:37.908
No download requests in the queue to start downloads for. | 2022-11-18 13:08:37.908
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-11-17 19:26:03.318840 | 2022-11-18 13:08:37.914
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: VXH22-CFE | 2022-11-18 13:08:37.951
Teton CME Order Routing | Received security definition for symbol VXH22-CFE | 2022-11-18 13:08:37.951
SC Data - All Services | Network connection to server complete. | 2022-11-18 13:08:37.951
SC Data - All Services | Starting socket receive thread. | 2022-11-18 13:08:37.951
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-11-18 13:08:37.951
Updated verified funded futures trading account ending date to: 2022-12-18 13:08:37 | 2022-11-18 13:08:37.956
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=7PV1252 | 2022-11-18 13:08:37.970
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-11-18 13:08:38.026
SC Data - All Services | Sending logon request message. | 2022-11-18 13:08:38.026
SC Data - All Services | Received logon response. | 2022-11-18 13:08:38.714
SC Data - All Services | Server Name: SC Realtime Server. | 2022-11-18 13:08:38.714
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 13:08:38.714
SC Data - All Services | Successfully connected. | 2022-11-18 13:08:38.714
SC Data - All Services | Trading is not supported. | 2022-11-18 13:08:38.714
SC Data - All Services | Restarting real-time data updates for symbol: VXH22-CFE -> VXH22_FUT_CFE | 2022-11-18 13:08:38.714
SC Data - All Services | Real-time data for symbol VXH22-CFE is currently unavailable. | 2022-11-18 13:08:38.875
SC Data - All Services | Received security definition for symbol VXH22-CFE | 2022-11-18 13:08:38.875
ESZ22_FUT_CME [CBV] 1 Min #1 | Reloading chart. | 2022-11-18 13:10:49.158
ESZ22_FUT_CME [CBV] 1 Min #1 | Performing continuous chart historical Daily data download for symbol ESZ22_FUT_CME starting at last date in file. | 2022-11-18 13:10:49.160
Starting DelayedDownloadMonitoringTimer | 2022-11-18 13:10:49.160
Starting HDTimeoutTimer | 2022-11-18 13:10:49.160
Added historical Daily data request for ESZ22_FUT_CME to the queue. | 2022-11-18 13:10:49.160
Triggering next historical data download in queue. | 2022-11-18 13:10:49.160
ESZ22_FUT_CME [CBV] 1 Min #1 | Waiting for historical downloads to complete with the IDs: 1, | 2022-11-18 13:10:49.173
Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffe383f0000 | 2022-11-18 13:10:49.178
ESZ22_FUT_CME [CBV] 120 Min #5 | Reloading chart. | 2022-11-18 13:10:49.189
ESZ22_FUT_CME [CBV] 120 Min #5 | Waiting for historical downloads to complete with the IDs: 1, | 2022-11-18 13:10:49.205
ESZ22_FUT_CME [CBV] #3 | Reloading chart. | 2022-11-18 13:10:49.215
ESZ22_FUT_CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 1, | 2022-11-18 13:10:49.229
ESZ22_FUT_CME [CBV] #2 | Reloading chart. | 2022-11-18 13:10:49.235
ESZ22_FUT_CME [CBV] #2 | Waiting for historical downloads to complete with the IDs: 1, | 2022-11-18 13:10:49.258
ESZ22_FUT_CME [CBV] 30 Min #4 | Reloading chart. | 2022-11-18 13:10:49.268
ESZ22_FUT_CME [CBV] 30 Min #4 | Waiting for historical downloads to complete with the IDs: 1, | 2022-11-18 13:10:49.283
ESZ22_FUT_CME [CBV] Daily #7 | Reloading chart. | 2022-11-18 13:10:49.294
ESZ22_FUT_CME [CBV] Daily #7 | Waiting for historical downloads to complete with the IDs: 1, | 2022-11-18 13:10:49.622
ESZ22_FUT_CME [CBV] 480 Min #6 | Reloading chart. | 2022-11-18 13:10:49.632
ESZ22_FUT_CME [CBV] 480 Min #6 | Waiting for historical downloads to complete with the IDs: 1, | 2022-11-18 13:10:49.656
ESZ22_FUT_CME [CBV] 3 Min #8 | Reloading chart. | 2022-11-18 13:10:49.710
ESZ22_FUT_CME [CBV] 3 Min #8 | Waiting for historical downloads to complete with the IDs: 1, | 2022-11-18 13:10:49.725
ESZ22_FUT_CME [CBV] 2000 Volume #9 | Reloading chart. | 2022-11-18 13:10:49.775
ESZ22_FUT_CME [CBV] 2000 Volume #9 | Waiting for historical downloads to complete with the IDs: 1, | 2022-11-18 13:10:49.790
ADR-NYSE [CBV] 1 Min #10 | Reloading chart. | 2022-11-18 13:10:49.843
ADR-NYSE [CBV] 1 Min #10 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2022-11-18 13:10:49.843
ADR-NYSE [CBV] 1 Min #10 | There are no continuous futures contract symbols. Loading data normally. | 2022-11-18 13:10:49.843
ESZ22_FUT_CME [CBV] 3 Min #11 | Reloading chart. | 2022-11-18 13:10:49.863
ESZ22_FUT_CME [CBV] 3 Min #11 | Waiting for historical downloads to complete with the IDs: 1, | 2022-11-18 13:10:49.870
Mapping ESZ22_FUT_CME to ESZ22. Service code: cme | 2022-11-18 13:10:49.881
HD Request # 1 | Downloading Historical Daily chart data for ESZ22_FUT_CME. Starting date: 2022-11-15. Service: sc_futures_direct.dtc.trading | 2022-11-18 13:10:49.882
ADR-NYSE [CBV-D] 1 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-11-18 13:10:49.942
SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-NYSE. ID: 3 Service code: statscalc | 2022-11-18 13:10:50.352
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2022-11-18 13:10:50.352
SC DTC Data with Market Depth | Requesting security definition data for: ADR-NYSE. ID: 3 | 2022-11-18 13:10:50.354
Starting DelayedDownloadMonitoringTimer | 2022-11-18 13:10:50.354
Starting HDTimeoutTimer | 2022-11-18 13:10:50.354
Added historical Intraday data request for ADR-NYSE to the queue. | 2022-11-18 13:10:50.354
Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'. | 2022-11-18 13:10:50.354
Triggering next historical data download in queue. | 2022-11-18 13:10:50.355
Delaying start of download for ADR-NYSE. | 2022-11-18 13:10:50.366
DTC Client socket (4) | Creating socket. | 2022-11-18 13:10:50.403
DTC Client socket (4) | New receive buffer size: 5242880 | 2022-11-18 13:10:50.403
DTC Client socket (4) | Connecting to IP: 142.215.18.104. | 2022-11-18 13:10:50.403
SC DTC Data with Market Depth | Network connection to server complete. | 2022-11-18 13:10:50.453
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-11-18 13:10:50.453
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-11-18 13:10:50.453
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-11-18 13:10:50.515
SC DTC Data with Market Depth | Sending logon request message. | 2022-11-18 13:10:50.515
HD Request # 1 | Requesting historical Daily data for ESZ22 starting at 2022-11-14. SC External HD service. | 2022-11-18 13:10:50.569
HD Request # 1 | Receiving historical Daily data for ESZ22_FUT_CME starting at 2022-11-15. | 2022-11-18 13:10:50.821
HD Request # 1 | Writing historical Daily data to the file ESZ22_FUT_CME.dly. | 2022-11-18 13:10:50.822
HD Request # 1 | Bytes received: 238 | 2022-11-18 13:10:50.826
HD Request # 1 | Received 4 Daily data records from 2022-11-15 00:00:00 to 2022-11-17 00:00:00 (3.0 days) and wrote 3 records for ESZ22_FUT_CME | 2022-11-18 13:10:50.826
HD Request # 1 | Completion time: 1s. | 2022-11-18 13:10:50.826
HD Request # 1 | Daily data download complete for ESZ22_FUT_CME. Unique request ID: 1 | 2022-11-18 13:10:50.826
Removing historical data download ID 1. | 2022-11-18 13:10:50.826
Triggering next historical data download in queue. | 2022-11-18 13:10:50.826
No download requests in the queue to start downloads for. | 2022-11-18 13:10:50.827
ESZ22_FUT_CME [CBV] 3 Min #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-11-18 13:10:50.879
ESZ22_FUT_CME [CBV] 3 Min #11 | Reloading chart. | 2022-11-18 13:10:50.880
ESZ22_FUT_CME [CBV] 480 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-11-18 13:10:51.139
ESZ22_FUT_CME [CBV] 480 Min #6 | Reloading chart. | 2022-11-18 13:10:51.140
SC DTC Data with Market Depth | Received logon response. | 2022-11-18 13:10:51.175
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-11-18 13:10:51.175
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 13:10:51.175
SC DTC Data with Market Depth | Successfully connected. | 2022-11-18 13:10:51.175
SC DTC Data with Market Depth | Trading is not supported. | 2022-11-18 13:10:51.175
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NYSE | 2022-11-18 13:10:51.175
ESZ22_FUT_CME [CBV] 1 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-11-18 13:10:51.191
ESZ22_FUT_CME [CBV] 1 Min #1 | Reloading chart. | 2022-11-18 13:10:51.192
ESZ22_FUT_CME [CBV] 120 Min #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-11-18 13:10:51.211
ESZ22_FUT_CME [CBV] 120 Min #5 | Reloading chart. | 2022-11-18 13:10:51.212
ESZ22_FUT_CME [CBV] 3 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-11-18 13:10:51.244
ESZ22_FUT_CME [CBV] 3 Min #8 | Reloading chart. | 2022-11-18 13:10:51.246
ESZ22_FUT_CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-11-18 13:10:51.255
ESZ22_FUT_CME [CBV] #3 | Reloading chart. | 2022-11-18 13:10:51.255
ESZ22_FUT_CME [CBV] #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-11-18 13:10:51.275
ESZ22_FUT_CME [CBV] #2 | Reloading chart. | 2022-11-18 13:10:51.276
ESZ22_FUT_CME [CBV] 2000 Volume #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-11-18 13:10:51.297
ESZ22_FUT_CME [CBV] 2000 Volume #9 | Reloading chart. | 2022-11-18 13:10:51.297
ESZ22_FUT_CME [CBV] 30 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-11-18 13:10:51.310
ESZ22_FUT_CME [CBV] 30 Min #4 | Reloading chart. | 2022-11-18 13:10:51.311
ESZ22_FUT_CME [CBV] Daily #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-11-18 13:10:51.322
ESZ22_FUT_CME [CBV] Daily #7 | Reloading chart. | 2022-11-18 13:10:51.324
SC DTC Data with Market Depth | Received security definition for symbol ADR-NYSE | 2022-11-18 13:10:51.910
ESZ22_FUT_CME [CBV] 3 Min #11 | Reloading chart. | 2022-11-18 13:10:51.918
ESZ22_FUT_CME [CBV] 480 Min #6 | Reloading chart. | 2022-11-18 13:10:51.935
ESZ22_FUT_CME [CBV] 1 Min #1 | Reloading chart. | 2022-11-18 13:10:52.037
ESZ22_FUT_CME [CBV] 120 Min #5 | Reloading chart. | 2022-11-18 13:10:52.050
ESZ22_FUT_CME [CBV] 3 Min #8 | Reloading chart. | 2022-11-18 13:10:52.106
ESZ22_FUT_CME [CBV] #3 | Reloading chart. | 2022-11-18 13:10:52.151
ESZ22_FUT_CME [CBV] #2 | Reloading chart. | 2022-11-18 13:10:52.193
ESZ22_FUT_CME [CBV] Daily #7 | Reloading chart. | 2022-11-18 13:10:52.288
ESZ22_FUT_CME [CBV] 30 Min #4 | Reloading chart. | 2022-11-18 13:10:53.669
ESZ22_FUT_CME [CBV] 2000 Volume #9 | Reloading chart. | 2022-11-18 13:10:53.707
SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME (ESZ22). ID: 2 Service code: cme | 2022-11-18 13:10:53.803
SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 10048 | 2022-11-18 13:10:53.803
SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME (ESZ22). ID: 2 | 2022-11-18 13:10:53.803
Requesting market depth updates for: ESZ22_FUT_CME if supported. | 2022-11-18 13:10:53.803
Separate subscription for market depth updates not supported. ESZ22_FUT_CME | 2022-11-18 13:10:53.803
Added historical Intraday data request for ESZ22_FUT_CME to the queue. | 2022-11-18 13:10:53.804
Intraday data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-11-18 13:10:53.804
Triggering next historical data download in queue. | 2022-11-18 13:10:53.804
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ22_FUT_CME | 2022-11-18 13:10:53.869
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-11-18 13:10:53.869
DTC Client socket (3) | Creating socket. | 2022-11-18 13:10:53.897
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-11-18 13:10:53.898
DTC Client socket (3) | Connecting to IP: 142.215.18.107. | 2022-11-18 13:10:53.898
SC Data - All Services | Network connection to server complete. | 2022-11-18 13:10:53.960
SC Data - All Services | Starting socket receive thread. | 2022-11-18 13:10:53.960
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-11-18 13:10:53.960
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-11-18 13:10:54.032
SC Data - All Services | Sending logon request message. | 2022-11-18 13:10:54.032
SC Data - All Services | Received logon response. | 2022-11-18 13:10:54.817
SC Data - All Services | Server Name: SC Realtime Server. | 2022-11-18 13:10:54.817
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 13:10:54.817
SC Data - All Services | Successfully connected. | 2022-11-18 13:10:54.817
SC Data - All Services | Trading is not supported. | 2022-11-18 13:10:54.817
Starting DelayedDownloadMonitoringTimer | 2022-11-18 13:10:54.817
Starting HDTimeoutTimer | 2022-11-18 13:10:54.817
Added historical Market depth data request for ESZ22_FUT_CME to the queue. | 2022-11-18 13:10:54.817
Market depth data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-11-18 13:10:54.817
Triggering next historical data download in queue. | 2022-11-18 13:10:54.817
SC Data - All Services | Restarting real-time data updates for symbol: ESZ22_FUT_CME -> ESZ22. Market Depth data restarted. | 2022-11-18 13:10:54.817
HD Request # 2 | Downloading Market depth data for ESZ22_FUT_CME. Service: cme.marketdepth. | 2022-11-18 13:10:54.817
HD Request # 2 | Download start date-time: 2022-11-18 07:11:49.673772. | 2022-11-18 13:10:54.817
HD Request # 2 | Using server: ds23.sierracharts.com port 10149 | 2022-11-18 13:10:54.817
Socket (5) | Creating socket. | 2022-11-18 13:10:54.908
Socket (5) | New receive buffer size: 5242880 | 2022-11-18 13:10:54.908
Socket (5) | Connecting to IP: 142.215.18.103. | 2022-11-18 13:10:54.908
HD Request # 2 | Setting DTC encoding to Binary VLS | 2022-11-18 13:10:55.028
HD Request # 2 | Sending historical data logon request message. | 2022-11-18 13:10:55.028
SC Data - All Services | Received security definition for symbol ESZ22_FUT_CME | 2022-11-18 13:10:55.028
SC Data - All Services | Market Depth data has been rejected for symbol: ESZ22_FUT_CME. Not authorized for market depth. | 2022-11-18 13:10:55.028
HD Request # 2 | Requesting market depth data. Start date-time: 2022-11-18 07:11:49. Symbol: ESZ22 | 2022-11-18 13:10:55.632
HD Request # 2 | Decompressing data. | 2022-11-18 13:10:55.686
HD Request # 2 | Receiving market depth data for ESZ22_FUT_CME starting at 2022-11-18 07:11:50.145000 | 2022-11-18 13:10:55.895
HD Request # 3 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc | 2022-11-18 13:10:56.377
HD Request # 3 | Download start date-time: 2022-11-18 01:00:04.000000. File last date-time: 2022-11-18 01:00:04.000000 | 2022-11-18 13:10:56.378
HD Request # 3 | Using server: ds12.sierracharts.com port 10149 | 2022-11-18 13:10:56.378
Socket (6) | Creating socket. | 2022-11-18 13:10:56.378
Socket (6) | New receive buffer size: 5242880 | 2022-11-18 13:10:56.378
Socket (6) | Connecting to IP: 142.215.18.104. | 2022-11-18 13:10:56.378
HD Request # 3 | Setting DTC encoding to Binary VLS | 2022-11-18 13:10:56.507
HD Request # 3 | Sending historical data logon request message. | 2022-11-18 13:10:56.507
HD Request # 3 | Requesting Intraday data. Start date-time: 2022-11-18 01:00:04. Record interval: 0. Symbol: ADR-NYSE | 2022-11-18 13:10:57.083
HD Request # 3 | Decompressing data. | 2022-11-18 13:10:57.180
HD Request # 3 | Receiving Intraday data for ADR-NYSE starting at 2022-11-18 01:00:04.000000 | 2022-11-18 13:10:57.181
HD Request # 2 | Timestamp of first market depth data file record written: 2022-11-18 07:11:50.145000. | 2022-11-18 13:10:57.292
Socket (6) | CloseSocket call. | 2022-11-18 13:10:57.580
Socket (6) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:10:57.580
Historical data download thread signaled to stop. | 2022-11-18 13:10:57.580
HD Request # 3 | Timestamp of first Intraday data file record written: 2022-11-18 09:00:00.000000. | 2022-11-18 13:10:57.580
HD Request # 3 | Received 14735 Intraday data records from 2022-11-18 01:00:04.000000 to 2022-11-18 13:10:54.000000 (12.2 hours) and wrote 14734 records for ADR-NYSE | 2022-11-18 13:10:57.581
HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2022-11-18 13:10:54.000000 | 2022-11-18 13:10:57.606
Added 5 Time and Sales records to Intraday data file for ADR-NYSE after download. | 2022-11-18 13:10:57.607
HD Request # 3 | Completion time: 1s. | 2022-11-18 13:10:57.615
HD Request # 3 | Intraday data download complete for ADR-NYSE. Unique request ID: 2 | 2022-11-18 13:10:57.615
Removing historical data download ID 2. | 2022-11-18 13:10:57.615
Real-time Intraday chart data file updates started for ADR-NYSE | 2022-11-18 13:10:57.615
Intraday chart data file opened for ADR-NYSE | 2022-11-18 13:10:57.615
HD Request # 3 | Enabling Intraday chart updating for symbol. | 2022-11-18 13:10:57.615
Triggering next historical data download in queue. | 2022-11-18 13:10:57.615
Delaying start of download for ESZ22_FUT_CME. | 2022-11-18 13:10:57.615
Socket (6) | Socket gracefully closed by remote side. | 2022-11-18 13:10:57.670
Socket (6) | Closed. | 2022-11-18 13:10:57.670
HD Request # 4 | Downloading Intraday chart data for ESZ22_FUT_CME to the file ESZ22_FUT_CME.scid. Service: cme | 2022-11-18 13:11:00.376
HD Request # 4 | Download start date-time: 2022-11-18 07:11:45.000000. File last date-time: 2022-11-18 07:11:45.238018 | 2022-11-18 13:11:00.378
HD Request # 4 | Using server: ds23.sierracharts.com port 10150 | 2022-11-18 13:11:00.378
Socket (6) | Creating socket. | 2022-11-18 13:11:00.378
Socket (6) | New receive buffer size: 5242880 | 2022-11-18 13:11:00.378
Socket (6) | Connecting to IP: 142.215.18.103. | 2022-11-18 13:11:00.378
HD Request # 4 | Setting DTC encoding to Binary VLS | 2022-11-18 13:11:00.516
HD Request # 4 | Sending historical data logon request message. | 2022-11-18 13:11:00.516
HD Request # 4 | Requesting Intraday data. Start date-time: 2022-11-18 07:11:45. Record interval: 0. Symbol: ESZ22 | 2022-11-18 13:11:01.144
HD Request # 4 | Decompressing data. | 2022-11-18 13:11:01.223
HD Request # 4 | Receiving Intraday data for ESZ22_FUT_CME starting at 2022-11-18 07:11:45.238000 | 2022-11-18 13:11:01.424
HD Request # 4 | Timestamp of first Intraday data file record written: 2022-11-18 07:11:50.580000. | 2022-11-18 13:11:02.125
Opened cached Intraday file: C:\SierraChart\Data\ADR-NYSE.scid. Thread ID: 11208 | 2022-11-18 13:11:02.309
Socket (6) | CloseSocket call. | 2022-11-18 13:11:03.448
Socket (6) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:11:03.448
Historical data download thread signaled to stop. | 2022-11-18 13:11:03.448
HD Request # 4 | Received 103240 Intraday data records from 2022-11-18 07:11:45.238000 to 2022-11-18 13:10:57.744007 (6.0 hours) and wrote 103221 records for ESZ22_FUT_CME | 2022-11-18 13:11:03.448
HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2022-11-18 13:10:57.744007 | 2022-11-18 13:11:03.466
Added 2 Time and Sales records to Intraday data file for ESZ22_FUT_CME after download. | 2022-11-18 13:11:03.473
HD Request # 4 | Completion time: 3s. | 2022-11-18 13:11:03.473
HD Request # 4 | Intraday data download complete for ESZ22_FUT_CME. Unique request ID: 3 | 2022-11-18 13:11:03.473
Removing historical data download ID 3. | 2022-11-18 13:11:03.473
Real-time Intraday chart data file updates started for ESZ22_FUT_CME | 2022-11-18 13:11:03.473
Intraday chart data file opened for ESZ22_FUT_CME | 2022-11-18 13:11:03.473
HD Request # 4 | Enabling Intraday chart updating for symbol. | 2022-11-18 13:11:03.473
Triggering next historical data download in queue. | 2022-11-18 13:11:03.473
No download requests in the queue to start downloads for. | 2022-11-18 13:11:03.473
Socket (6) | Socket gracefully closed by remote side. | 2022-11-18 13:11:03.499
Socket (6) | Closed. | 2022-11-18 13:11:03.499
Opened cached Intraday file: C:\SierraChart\Data\ESZ22_FUT_CME.scid. Thread ID: 11208 | 2022-11-18 13:11:07.681
ESZ22_FUT_CME [CBV] 1 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 09:11:00. Next Bar Date Time: 2022-11-14 09:00:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:11:14.869
ESZ22_FUT_CME [CBV] 1 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 11:15:00. Next Bar Date Time: 2022-11-14 11:04:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:11:15.223
ESZ22_FUT_CME [CBV] 3 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 09:09:00. Next Bar Date Time: 2022-11-14 09:00:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:11:16.546
ESZ22_FUT_CME [CBV] 3 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 11:15:00. Next Bar Date Time: 2022-11-14 11:03:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:11:16.791
Socket (5) | CloseSocket call. | 2022-11-18 13:11:19.206
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:11:19.206
Historical data download thread signaled to stop. | 2022-11-18 13:11:19.206
HD Request # 2 | Received 1265472 Market depth data records from 2022-11-18 07:11:50.145000 to 2022-11-18 13:11:14.477000 (6.0 hours) and wrote 1265472 records for ESZ22_FUT_CME | 2022-11-18 13:11:19.207
HD Request # 2 | Completion time: 25s. | 2022-11-18 13:11:19.207
HD Request # 2 | Market depth data download complete for ESZ22_FUT_CME. Unique request ID: 4 | 2022-11-18 13:11:19.207
Removing historical data download ID 4. | 2022-11-18 13:11:19.207
Real-time market depth file updates started for ESZ22_FUT_CME | 2022-11-18 13:11:19.207
Socket (5) | Socket gracefully closed by remote side. | 2022-11-18 13:11:19.270
Socket (5) | Closed. | 2022-11-18 13:11:19.270
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ22_FUT_CME.2022-11-18.depth | 2022-11-18 13:11:20.247
Triggering next historical data download in queue. | 2022-11-18 13:11:20.247
No download requests in the queue to start downloads for. | 2022-11-18 13:11:20.247
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ22_FUT_CME.2022-11-18.depth | 2022-11-18 13:11:20.373
Loading market depth data. | 2022-11-18 13:11:20.477
Loaded depth data records for ESZ22_FUT_CME 2022-11-18 from 2022-11-17 23:21:42.023000 to 2022-11-18 01:11:45.238000. | 2022-11-18 13:11:20.554
ESZ22_FUT_CME [CBV] #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 09:11:00. Next Bar Date Time: 2022-11-14 09:00:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:11:25.884
ESZ22_FUT_CME [CBV] #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 11:15:00. Next Bar Date Time: 2022-11-14 11:04:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:11:26.056
ESZ22_FUT_CME [CBV] 30 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 11:15:00. Next Bar Date Time: 2022-11-14 10:45:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:11:32.409
ESZ22_FUT_CME [CBV] 2000 Volume #9 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 09:11:14. Next Bar Date Time: 2022-11-14 09:00:03. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:11:39.825
ESZ22_FUT_CME [CBV] 2000 Volume #9 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 11:14:49. Next Bar Date Time: 2022-11-14 11:04:26. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:11:40.000
ESZ22_FUT_CME [CBV] 3 Min #8 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 09:09:00. Next Bar Date Time: 2022-11-14 09:00:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:11:40.448
ESZ22_FUT_CME [CBV] 3 Min #8 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 11:15:00. Next Bar Date Time: 2022-11-14 11:03:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:11:40.609
ESZ22_FUT_CME [CBV][M] 2000 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-11-18 13:11:42.354
ESZ22_FUT_CME [CBV][M] 3 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-11-18 13:11:43.270
ESZ22_FUT_CME [CBV] #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 09:11:00. Next Bar Date Time: 2022-11-14 09:00:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:12:04.784
ESZ22_FUT_CME [CBV] #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 11:15:00. Next Bar Date Time: 2022-11-14 11:04:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:12:04.841
ESZ22_FUT_CME [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-11-18 13:12:05.645
ESZ22_FUT_CME [CBV][M] 3 Min #11 | Reloading chart. | 2022-11-18 13:41:45.045
ESZ22_FUT_CME [CBV][M] 3 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 09:09:00. Next Bar Date Time: 2022-11-14 09:00:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:41:53.208
ESZ22_FUT_CME [CBV][M] 3 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 11:15:00. Next Bar Date Time: 2022-11-14 11:03:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 13:41:53.273
Loading market depth data. | 2022-11-18 13:41:54.168
Loaded depth data records for ESZ22_FUT_CME 2022-11-18 from 2022-11-17 23:21:42.023000 to 2022-11-18 07:41:39.239000. | 2022-11-18 13:41:54.453
File >> Disconnect selected. | 2022-11-18 13:49:20.222
Teton CME Order Routing | Waiting for socket receive thread to end | 2022-11-18 13:49:20.227
DTC Client socket (1) | CloseSocket call. | 2022-11-18 13:49:20.227
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-11-18 13:49:20.227
DTC Client socket (1) | Max send buffer size during socket life: 329 | 2022-11-18 13:49:20.227
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:49:20.227
SC Data - All Services | Waiting for socket receive thread to end | 2022-11-18 13:49:20.228
DTC Client socket (3) | CloseSocket call. | 2022-11-18 13:49:20.228
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:49:20.228
SC Data - All Services | Disconnected from the server. | 2022-11-18 13:49:20.228
DTC Client socket (2) | CloseSocket call. | 2022-11-18 13:49:20.228
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:49:20.228
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-11-18 13:49:20.228
DTC Client socket (4) | CloseSocket call. | 2022-11-18 13:49:20.228
SC DTC Data with Market Depth | Disconnected from the server. | 2022-11-18 13:49:20.228
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:49:20.228
Teton CME Order Routing | Disconnected. | 2022-11-18 13:49:20.228
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-11-18 13:49:20.287
DTC Client socket (1) | Closed. | 2022-11-18 13:49:20.287
DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-11-18 13:49:20.287
DTC Client socket (3) | Closed. | 2022-11-18 13:49:20.287
DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-11-18 13:49:20.288
DTC Client socket (4) | Closed. | 2022-11-18 13:49:20.288
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-11-18 13:49:20.288
DTC Client socket (2) | Closed. | 2022-11-18 13:49:20.288
Teton CME Order Routing | Firm: Phillip Capital | 2022-11-18 13:49:30.111
Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11089 | 2022-11-18 13:49:30.111
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-11-18 13:49:30.223
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-11-18 13:49:30.223
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2022-11-18 13:49:30.223
Teton CME Order Routing | Network connection to server complete. | 2022-11-18 13:49:30.266
Teton CME Order Routing | Starting socket receive thread. | 2022-11-18 13:49:30.266
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-11-18 13:49:30.266
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-11-18 13:49:30.417
Teton CME Order Routing | Sending logon request message. | 2022-11-18 13:49:30.417
Teton CME Order Routing | Received logon response. | 2022-11-18 13:49:30.975
Teton CME Order Routing | Server Name: SC DTC Server. Build=43909M. | 2022-11-18 13:49:30.975
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 13:49:30.975
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-11-18 13:49:30.975
Teton CME Order Routing | Trading is supported. | 2022-11-18 13:49:30.975
Teton CME Order Routing | Order cancel and replace is supported. | 2022-11-18 13:49:30.975
Teton CME Order Routing | OCO Orders supported. | 2022-11-18 13:49:30.975
Teton CME Order Routing | Bracket Orders supported. | 2022-11-18 13:49:30.975
Teton CME Order Routing | Connected to server complete. | 2022-11-18 13:49:30.975
Triggering next historical data download in queue. | 2022-11-18 13:49:30.976
Subscribing to symbol for symbol alert. VXH22-CFE | 2022-11-18 13:49:30.976
Mapping VXH22-CFE to VXH22_FUT_CFE. Service code: cfe_exchange.data | 2022-11-18 13:49:30.976
Using symbol data fast lookup vector | 2022-11-18 13:49:30.976
SC Data - All Services | Starting real-time market data updates for: VXH22-CFE (VXH22_FUT_CFE). ID: 1 Service code: cfe_exchange.data | 2022-11-18 13:49:30.976
SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 443 | 2022-11-18 13:49:30.976
SC Data - All Services | Requesting security definition data for: VXH22-CFE (VXH22_FUT_CFE). ID: 1 | 2022-11-18 13:49:30.976
Updated verified funded futures trading account ending date to: 2022-12-18 13:49:30 | 2022-11-18 13:49:30.976
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-11-18 13:49:30.989
No download requests in the queue to start downloads for. | 2022-11-18 13:49:30.989
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-11-17 19:26:03.318840 | 2022-11-18 13:49:31.005
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: VXH22-CFE | 2022-11-18 13:49:31.022
Teton CME Order Routing | Received security definition for symbol VXH22-CFE | 2022-11-18 13:49:31.022
Updated verified funded futures trading account ending date to: 2022-12-18 13:49:31 | 2022-11-18 13:49:31.035
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=7PV1252 | 2022-11-18 13:49:31.057
DTC Client socket (1) | Creating socket. | 2022-11-18 13:49:31.089
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-11-18 13:49:31.089
DTC Client socket (1) | Connecting to IP: 38.65.8.115. | 2022-11-18 13:49:31.089
SC Data - All Services | Network connection to server complete. | 2022-11-18 13:49:31.149
SC Data - All Services | Starting socket receive thread. | 2022-11-18 13:49:31.149
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-11-18 13:49:31.149
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-11-18 13:49:31.211
SC Data - All Services | Sending logon request message. | 2022-11-18 13:49:31.211
SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-NYSE. ID: 2 Service code: statscalc | 2022-11-18 13:49:31.315
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2022-11-18 13:49:31.315
SC DTC Data with Market Depth | Requesting security definition data for: ADR-NYSE. ID: 2 | 2022-11-18 13:49:31.315
Added historical Intraday data request for ADR-NYSE to the queue. | 2022-11-18 13:49:31.316
Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'. | 2022-11-18 13:49:31.316
Triggering next historical data download in queue. | 2022-11-18 13:49:31.316
Delaying start of download for ADR-NYSE. | 2022-11-18 13:49:31.325
Mapping ESZ22_FUT_CME to ESZ22_FUT_CME. Service code: cme | 2022-11-18 13:49:31.325
SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME (ESZ22_FUT_CME). ID: 3 Service code: cme | 2022-11-18 13:49:31.325
SC Data - All Services | Connecting to the server ds28.sierracharts.com. Port 443 | 2022-11-18 13:49:31.325
SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME (ESZ22_FUT_CME). ID: 3 | 2022-11-18 13:49:31.325
Added historical Intraday data request for ESZ22_FUT_CME to the queue. | 2022-11-18 13:49:31.326
Intraday data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-11-18 13:49:31.326
Triggering next historical data download in queue. | 2022-11-18 13:49:31.326
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ22_FUT_CME | 2022-11-18 13:49:31.372
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-11-18 13:49:31.372
Requesting market depth updates for: ESZ22_FUT_CME if supported. | 2022-11-18 13:49:31.406
Separate subscription for market depth updates not supported. ESZ22_FUT_CME | 2022-11-18 13:49:31.406
DTC Client socket (3) | Creating socket. | 2022-11-18 13:49:31.412
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-11-18 13:49:31.412
DTC Client socket (3) | Connecting to IP: 142.215.18.105. | 2022-11-18 13:49:31.412
DTC Client socket (4) | Creating socket. | 2022-11-18 13:49:31.413
DTC Client socket (4) | New receive buffer size: 5242880 | 2022-11-18 13:49:31.413
DTC Client socket (4) | Connecting to IP: 142.215.18.126. | 2022-11-18 13:49:31.413
SC DTC Data with Market Depth | Network connection to server complete. | 2022-11-18 13:49:31.459
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-11-18 13:49:31.459
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-11-18 13:49:31.459
SC Data - All Services | Network connection to server complete. | 2022-11-18 13:49:31.466
SC Data - All Services | Starting socket receive thread. | 2022-11-18 13:49:31.466
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-11-18 13:49:31.466
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-11-18 13:49:31.537
SC DTC Data with Market Depth | Sending logon request message. | 2022-11-18 13:49:31.537
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-11-18 13:49:31.549
SC Data - All Services | Sending logon request message. | 2022-11-18 13:49:31.549
SC Data - All Services | Received logon response. | 2022-11-18 13:49:31.883
SC Data - All Services | Server Name: SC Realtime Server. | 2022-11-18 13:49:31.883
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 13:49:31.883
SC Data - All Services | Successfully connected. | 2022-11-18 13:49:31.883
SC Data - All Services | Trading is not supported. | 2022-11-18 13:49:31.883
SC Data - All Services | Restarting real-time data updates for symbol: VXH22-CFE -> VXH22_FUT_CFE | 2022-11-18 13:49:31.884
SC Data - All Services | Real-time data for symbol VXH22-CFE is currently unavailable. | 2022-11-18 13:49:32.040
SC Data - All Services | Received security definition for symbol VXH22-CFE | 2022-11-18 13:49:32.040
SC DTC Data with Market Depth | Received logon response. | 2022-11-18 13:49:32.194
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-11-18 13:49:32.194
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 13:49:32.194
SC DTC Data with Market Depth | Successfully connected. | 2022-11-18 13:49:32.194
SC DTC Data with Market Depth | Trading is not supported. | 2022-11-18 13:49:32.194
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NYSE | 2022-11-18 13:49:32.194
SC Data - All Services | Received logon response. | 2022-11-18 13:49:32.306
SC Data - All Services | Server Name: SC Realtime Server. | 2022-11-18 13:49:32.306
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 13:49:32.306
SC Data - All Services | Successfully connected. | 2022-11-18 13:49:32.306
SC Data - All Services | Trading is not supported. | 2022-11-18 13:49:32.306
Added historical Market depth data request for ESZ22_FUT_CME to the queue. | 2022-11-18 13:49:32.306
Market depth data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-11-18 13:49:32.306
Triggering next historical data download in queue. | 2022-11-18 13:49:32.306
SC Data - All Services | Restarting real-time data updates for symbol: ESZ22_FUT_CME -> ESZ22_FUT_CME. Market Depth data restarted. | 2022-11-18 13:49:32.306
HD Request # 5 | Downloading Market depth data for ESZ22_FUT_CME. Service: cme.marketdepth. | 2022-11-18 13:49:32.306
HD Request # 5 | Download start date-time: 2022-11-18 13:49:20.227908. | 2022-11-18 13:49:32.306
HD Request # 5 | Using server: ds26.sierracharts.com port 10150 | 2022-11-18 13:49:32.307
SC DTC Data with Market Depth | Received security definition for symbol ADR-NYSE | 2022-11-18 13:49:32.350
Socket (5) | Creating socket. | 2022-11-18 13:49:32.385
Socket (5) | New receive buffer size: 5242880 | 2022-11-18 13:49:32.385
Socket (5) | Connecting to IP: 142.215.18.107. | 2022-11-18 13:49:32.385
SC Data - All Services | Real-time data for symbol ESZ22_FUT_CME is currently unavailable. | 2022-11-18 13:49:32.461
SC Data - All Services | Received security definition for symbol ESZ22_FUT_CME | 2022-11-18 13:49:32.461
SC Data - All Services | Market Depth data has been rejected for symbol: ESZ22_FUT_CME. Not authorized for market depth. | 2022-11-18 13:49:32.461
HD Request # 5 | Setting DTC encoding to Binary VLS | 2022-11-18 13:49:32.487
HD Request # 5 | Sending historical data logon request message. | 2022-11-18 13:49:32.487
HD Request # 5 | Requesting market depth data. Start date-time: 2022-11-18 13:49:20. Symbol: ESZ22_FUT_CME | 2022-11-18 13:49:33.062
Socket (5) | CloseSocket call. | 2022-11-18 13:49:33.108
HD Request # 5 | Error downloading historical Market Depth data for ESZ22_FUT_CME. No market depth data files found. Path: F:\cme_exchange.data\MarketDepthData/ | 2022-11-18 13:49:33.109
Historical data download thread signaled to stop. | 2022-11-18 13:49:33.109
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:49:33.109
HD Request # 5 | Received 0 Market depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ESZ22_FUT_CME | 2022-11-18 13:49:33.109
HD Request # 5 | Completion time: 1s. | 2022-11-18 13:49:33.109
HD Request # 5 | Market depth data download complete for ESZ22_FUT_CME. Unique request ID: 7 | 2022-11-18 13:49:33.109
Removing historical data download ID 7. | 2022-11-18 13:49:33.109
Real-time market depth file updates started for ESZ22_FUT_CME | 2022-11-18 13:49:33.109
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ22_FUT_CME.2022-11-18.depth | 2022-11-18 13:49:33.109
Triggering next historical data download in queue. | 2022-11-18 13:49:33.109
No download requests in the queue to start downloads for. | 2022-11-18 13:49:33.109
Socket (5) | Socket gracefully closed by remote side. | 2022-11-18 13:49:33.154
Socket (5) | Closed. | 2022-11-18 13:49:33.154
HD Request # 6 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc | 2022-11-18 13:49:37.242
HD Request # 6 | Download start date-time: 2022-11-18 13:49:17.000000. File last date-time: 2022-11-18 13:49:17.953000 | 2022-11-18 13:49:37.243
HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2022-11-18 13:49:37.243
Socket (5) | Creating socket. | 2022-11-18 13:49:37.243
Socket (5) | New receive buffer size: 5242880 | 2022-11-18 13:49:37.243
Socket (5) | Connecting to IP: 142.215.18.105. | 2022-11-18 13:49:37.243
HD Request # 6 | Setting DTC encoding to Binary VLS | 2022-11-18 13:49:37.346
HD Request # 6 | Sending historical data logon request message. | 2022-11-18 13:49:37.346
HD Request # 6 | Requesting Intraday data. Start date-time: 2022-11-18 13:49:17. Record interval: 0. Symbol: ADR-NYSE | 2022-11-18 13:49:37.921
HD Request # 6 | Decompressing data. | 2022-11-18 13:49:37.969
HD Request # 6 | Receiving Intraday data for ADR-NYSE starting at 2022-11-18 13:49:17.000000 | 2022-11-18 13:49:37.969
Socket (5) | CloseSocket call. | 2022-11-18 13:49:37.970
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:49:37.970
Historical data download thread signaled to stop. | 2022-11-18 13:49:37.970
HD Request # 6 | Timestamp of first Intraday data file record written: 2022-11-18 13:49:18.000000. | 2022-11-18 13:49:37.970
HD Request # 6 | Received 18 Intraday data records from 2022-11-18 13:49:17.000000 to 2022-11-18 13:49:34.000000 (17.0 seconds) and wrote 17 records for ADR-NYSE | 2022-11-18 13:49:37.970
HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2022-11-18 13:49:34.000000 | 2022-11-18 13:49:37.983
Added 6 Time and Sales records to Intraday data file for ADR-NYSE after download. | 2022-11-18 13:49:37.983
HD Request # 6 | Completion time: 0s. | 2022-11-18 13:49:37.983
HD Request # 6 | Intraday data download complete for ADR-NYSE. Unique request ID: 5 | 2022-11-18 13:49:37.983
Removing historical data download ID 5. | 2022-11-18 13:49:37.983
Real-time Intraday chart data file updates started for ADR-NYSE | 2022-11-18 13:49:37.983
Intraday chart data file opened for ADR-NYSE | 2022-11-18 13:49:37.983
HD Request # 6 | Enabling Intraday chart updating for symbol. | 2022-11-18 13:49:37.983
Triggering next historical data download in queue. | 2022-11-18 13:49:37.983
HD Request # 7 | Downloading Intraday chart data for ESZ22_FUT_CME to the file ESZ22_FUT_CME.scid. Service: cme | 2022-11-18 13:49:37.983
HD Request # 7 | Download start date-time: 2022-11-18 13:49:17.000000. File last date-time: 2022-11-18 13:49:17.516018 | 2022-11-18 13:49:37.983
HD Request # 7 | Using server: ds26.sierracharts.com port 10150 | 2022-11-18 13:49:37.984
Socket (6) | Creating socket. | 2022-11-18 13:49:37.984
Socket (6) | New receive buffer size: 5242880 | 2022-11-18 13:49:37.984
Socket (6) | Connecting to IP: 142.215.18.107. | 2022-11-18 13:49:37.984
Socket (5) | Socket gracefully closed by remote side. | 2022-11-18 13:49:38.021
Socket (5) | Closed. | 2022-11-18 13:49:38.021
HD Request # 7 | Setting DTC encoding to Binary VLS | 2022-11-18 13:49:38.080
HD Request # 7 | Sending historical data logon request message. | 2022-11-18 13:49:38.080
HD Request # 7 | Requesting Intraday data. Start date-time: 2022-11-18 13:49:17. Record interval: 0. Symbol: ESZ22_FUT_CME | 2022-11-18 13:49:38.127
Socket (6) | CloseSocket call. | 2022-11-18 13:49:38.177
HD Request # 7 | Error downloading historical Intraday data for ESZ22_FUT_CME. Historical data file not available for symbol. | 2022-11-18 13:49:38.177
Historical data download thread signaled to stop. | 2022-11-18 13:49:38.177
Socket (6) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:49:38.177
HD Request # 7 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ESZ22_FUT_CME | 2022-11-18 13:49:38.177
HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2022-11-18 13:49:17.516018 | 2022-11-18 13:49:38.178
HD Request # 7 | Completion time: 1s. | 2022-11-18 13:49:38.178
HD Request # 7 | Intraday data download complete for ESZ22_FUT_CME. Unique request ID: 6 | 2022-11-18 13:49:38.178
Removing historical data download ID 6. | 2022-11-18 13:49:38.178
Real-time Intraday chart data file updates started for ESZ22_FUT_CME | 2022-11-18 13:49:38.178
Intraday chart data file opened for ESZ22_FUT_CME | 2022-11-18 13:49:38.178
HD Request # 7 | Enabling Intraday chart updating for symbol. | 2022-11-18 13:49:38.178
Triggering next historical data download in queue. | 2022-11-18 13:49:38.178
No download requests in the queue to start downloads for. | 2022-11-18 13:49:38.178
Socket (6) | Socket gracefully closed by remote side. | 2022-11-18 13:49:38.224
Socket (6) | Closed. | 2022-11-18 13:49:38.224
Opened cached Intraday file: C:\SierraChart\Data\ADR-NYSE.scid. Thread ID: 11208 | 2022-11-18 13:49:41.179
File >> Disconnect selected. | 2022-11-18 13:50:42.671
Teton CME Order Routing | Waiting for socket receive thread to end | 2022-11-18 13:50:42.676
DTC Client socket (2) | CloseSocket call. | 2022-11-18 13:50:42.676
DTC Client socket (2) | Max send buffers used during socket life: 3 | 2022-11-18 13:50:42.676
DTC Client socket (2) | Max send buffer size during socket life: 236 | 2022-11-18 13:50:42.676
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:50:42.676
SC Data - All Services | Waiting for socket receive thread to end | 2022-11-18 13:50:42.676
DTC Client socket (4) | CloseSocket call. | 2022-11-18 13:50:42.677
SC Data - All Services | Disconnected from the server. | 2022-11-18 13:50:42.677
SC Data - All Services | Waiting for socket receive thread to end | 2022-11-18 13:50:42.677
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:50:42.677
DTC Client socket (1) | CloseSocket call. | 2022-11-18 13:50:42.677
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-11-18 13:50:42.677
DTC Client socket (3) | CloseSocket call. | 2022-11-18 13:50:42.677
SC DTC Data with Market Depth | Disconnected from the server. | 2022-11-18 13:50:42.677
Teton CME Order Routing | Disconnected. | 2022-11-18 13:50:42.677
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:50:42.677
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:50:42.677
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-11-18 13:50:42.719
DTC Client socket (2) | Closed. | 2022-11-18 13:50:42.719
DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-11-18 13:50:42.728
DTC Client socket (4) | Closed. | 2022-11-18 13:50:42.728
DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-11-18 13:50:42.729
DTC Client socket (3) | Closed. | 2022-11-18 13:50:42.729
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-11-18 13:50:42.731
DTC Client socket (1) | Closed. | 2022-11-18 13:50:42.731
Teton CME Order Routing | Firm: Phillip Capital | 2022-11-18 13:50:46.177
Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11089 | 2022-11-18 13:50:46.177
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-11-18 13:50:46.180
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-11-18 13:50:46.180
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-11-18 13:50:46.180
Teton CME Order Routing | Network connection to server complete. | 2022-11-18 13:50:46.223
Teton CME Order Routing | Starting socket receive thread. | 2022-11-18 13:50:46.223
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-11-18 13:50:46.223
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-11-18 13:50:46.359
Teton CME Order Routing | Sending logon request message. | 2022-11-18 13:50:46.359
Teton CME Order Routing | Received logon response. | 2022-11-18 13:50:46.924
Teton CME Order Routing | Server Name: SC DTC Server. Build=43909M. | 2022-11-18 13:50:46.924
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 13:50:46.924
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-11-18 13:50:46.924
Teton CME Order Routing | Trading is supported. | 2022-11-18 13:50:46.924
Teton CME Order Routing | Order cancel and replace is supported. | 2022-11-18 13:50:46.924
Teton CME Order Routing | OCO Orders supported. | 2022-11-18 13:50:46.924
Teton CME Order Routing | Bracket Orders supported. | 2022-11-18 13:50:46.924
Teton CME Order Routing | Connected to server complete. | 2022-11-18 13:50:46.924
Triggering next historical data download in queue. | 2022-11-18 13:50:46.925
Subscribing to symbol for symbol alert. VXH22-CFE | 2022-11-18 13:50:46.925
Mapping VXH22-CFE to VXH22_FUT_CFE. Service code: cfe_exchange.data | 2022-11-18 13:50:46.925
Using symbol data fast lookup vector | 2022-11-18 13:50:46.925
SC Data - All Services | Starting real-time market data updates for: VXH22-CFE (VXH22_FUT_CFE). ID: 1 Service code: cfe_exchange.data | 2022-11-18 13:50:46.925
SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 443 | 2022-11-18 13:50:46.925
SC Data - All Services | Requesting security definition data for: VXH22-CFE (VXH22_FUT_CFE). ID: 1 | 2022-11-18 13:50:46.925
Updated verified funded futures trading account ending date to: 2022-12-18 13:50:46 | 2022-11-18 13:50:46.925
DTC Client socket (2) | Creating socket. | 2022-11-18 13:50:46.926
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-11-18 13:50:46.926
DTC Client socket (2) | Connecting to IP: 38.65.8.115. | 2022-11-18 13:50:46.926
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-11-18 13:50:46.937
No download requests in the queue to start downloads for. | 2022-11-18 13:50:46.938
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-11-17 19:26:03.318840 | 2022-11-18 13:50:46.963
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: VXH22-CFE | 2022-11-18 13:50:46.974
Teton CME Order Routing | Received security definition for symbol VXH22-CFE | 2022-11-18 13:50:46.974
SC Data - All Services | Network connection to server complete. | 2022-11-18 13:50:46.974
SC Data - All Services | Starting socket receive thread. | 2022-11-18 13:50:46.974
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-11-18 13:50:46.974
Updated verified funded futures trading account ending date to: 2022-12-18 13:50:46 | 2022-11-18 13:50:46.980
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=7PV1252 | 2022-11-18 13:50:47.012
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-11-18 13:50:47.025
SC Data - All Services | Sending logon request message. | 2022-11-18 13:50:47.025
SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-NYSE. ID: 2 Service code: statscalc | 2022-11-18 13:50:47.200
SC DTC Data with Market Depth | Connecting to the server ds13-3.sierracharts.com. Port 10048 | 2022-11-18 13:50:47.200
SC DTC Data with Market Depth | Requesting security definition data for: ADR-NYSE. ID: 2 | 2022-11-18 13:50:47.201
Added historical Intraday data request for ADR-NYSE to the queue. | 2022-11-18 13:50:47.201
Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'. | 2022-11-18 13:50:47.201
Triggering next historical data download in queue. | 2022-11-18 13:50:47.201
Delaying start of download for ADR-NYSE. | 2022-11-18 13:50:47.212
Mapping ESZ22_FUT_CME to ESZ22. Service code: cme | 2022-11-18 13:50:47.212
SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME (ESZ22). ID: 3 Service code: cme | 2022-11-18 13:50:47.212
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2022-11-18 13:50:47.212
SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME (ESZ22). ID: 3 | 2022-11-18 13:50:47.212
Added historical Intraday data request for ESZ22_FUT_CME to the queue. | 2022-11-18 13:50:47.212
Intraday data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-11-18 13:50:47.212
Triggering next historical data download in queue. | 2022-11-18 13:50:47.212
DTC Client socket (3) | Creating socket. | 2022-11-18 13:50:47.245
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-11-18 13:50:47.245
DTC Client socket (3) | Connecting to IP: 162.251.232.235. | 2022-11-18 13:50:47.245
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ22_FUT_CME | 2022-11-18 13:50:47.258
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-11-18 13:50:47.258
Requesting market depth updates for: ESZ22_FUT_CME if supported. | 2022-11-18 13:50:47.291
Separate subscription for market depth updates not supported. ESZ22_FUT_CME | 2022-11-18 13:50:47.291
DTC Client socket (4) | Creating socket. | 2022-11-18 13:50:47.292
DTC Client socket (4) | New receive buffer size: 5242880 | 2022-11-18 13:50:47.292
DTC Client socket (4) | Connecting to IP: 216.1.90.129. | 2022-11-18 13:50:47.292
SC DTC Data with Market Depth | Network connection to server complete. | 2022-11-18 13:50:47.321
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-11-18 13:50:47.321
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-11-18 13:50:47.321
SC Data - All Services | Network connection to server complete. | 2022-11-18 13:50:47.328
SC Data - All Services | Starting socket receive thread. | 2022-11-18 13:50:47.328
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-11-18 13:50:47.328
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-11-18 13:50:47.392
SC Data - All Services | Sending logon request message. | 2022-11-18 13:50:47.392
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-11-18 13:50:47.420
SC DTC Data with Market Depth | Sending logon request message. | 2022-11-18 13:50:47.420
SC Data - All Services | Received logon response. | 2022-11-18 13:50:47.714
SC Data - All Services | Server Name: SC Realtime Server. | 2022-11-18 13:50:47.714
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 13:50:47.714
SC Data - All Services | Successfully connected. | 2022-11-18 13:50:47.714
SC Data - All Services | Trading is not supported. | 2022-11-18 13:50:47.714
SC Data - All Services | Restarting real-time data updates for symbol: VXH22-CFE -> VXH22_FUT_CFE | 2022-11-18 13:50:47.714
SC Data - All Services | Real-time data for symbol VXH22-CFE is currently unavailable. | 2022-11-18 13:50:47.870
SC Data - All Services | Received security definition for symbol VXH22-CFE | 2022-11-18 13:50:47.870
SC Data - All Services | Received logon response. | 2022-11-18 13:50:48.111
SC Data - All Services | Server Name: SC Realtime Server. | 2022-11-18 13:50:48.111
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 13:50:48.111
SC Data - All Services | Successfully connected. | 2022-11-18 13:50:48.111
SC Data - All Services | Trading is not supported. | 2022-11-18 13:50:48.111
Added historical Market depth data request for ESZ22_FUT_CME to the queue. | 2022-11-18 13:50:48.111
Market depth data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-11-18 13:50:48.111
Triggering next historical data download in queue. | 2022-11-18 13:50:48.111
SC Data - All Services | Restarting real-time data updates for symbol: ESZ22_FUT_CME -> ESZ22. Market Depth data restarted. | 2022-11-18 13:50:48.111
HD Request # 8 | Downloading Market depth data for ESZ22_FUT_CME. Service: cme.marketdepth. | 2022-11-18 13:50:48.112
HD Request # 8 | Download start date-time: 2022-11-18 13:50:42.676923. | 2022-11-18 13:50:48.112
HD Request # 8 | Using server: ds21.sierracharts.com port 10149 | 2022-11-18 13:50:48.112
Socket (5) | Creating socket. | 2022-11-18 13:50:48.113
Socket (5) | New receive buffer size: 5242880 | 2022-11-18 13:50:48.113
Socket (5) | Connecting to IP: 216.1.90.129. | 2022-11-18 13:50:48.113
HD Request # 8 | Setting DTC encoding to Binary VLS | 2022-11-18 13:50:48.193
HD Request # 8 | Sending historical data logon request message. | 2022-11-18 13:50:48.193
SC Data - All Services | Received security definition for symbol ESZ22_FUT_CME | 2022-11-18 13:50:48.236
SC Data - All Services | Market Depth data has been rejected for symbol: ESZ22_FUT_CME. Not authorized for market depth. | 2022-11-18 13:50:48.236
SC DTC Data with Market Depth | Received logon response. | 2022-11-18 13:50:48.264
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-11-18 13:50:48.264
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 13:50:48.264
SC DTC Data with Market Depth | Successfully connected. | 2022-11-18 13:50:48.264
SC DTC Data with Market Depth | Trading is not supported. | 2022-11-18 13:50:48.264
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NYSE | 2022-11-18 13:50:48.264
SC DTC Data with Market Depth | Received security definition for symbol ADR-NYSE | 2022-11-18 13:50:48.420
HD Request # 8 | Requesting market depth data. Start date-time: 2022-11-18 13:50:42. Symbol: ESZ22 | 2022-11-18 13:50:48.710
HD Request # 8 | Decompressing data. | 2022-11-18 13:50:48.743
HD Request # 8 | Receiving market depth data for ESZ22_FUT_CME starting at 2022-11-18 13:50:42.678000 | 2022-11-18 13:50:48.743
Socket (5) | CloseSocket call. | 2022-11-18 13:50:48.743
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:50:48.743
Historical data download thread signaled to stop. | 2022-11-18 13:50:48.753
HD Request # 8 | Timestamp of first market depth data file record written: 2022-11-18 13:50:42.678000. | 2022-11-18 13:50:48.753
HD Request # 8 | Received 135 Market depth data records from 2022-11-18 13:50:42.678000 to 2022-11-18 13:50:44.144000 (1.5 seconds) and wrote 135 records for ESZ22_FUT_CME | 2022-11-18 13:50:48.753
HD Request # 8 | Completion time: 0s. | 2022-11-18 13:50:48.753
HD Request # 8 | Market depth data download complete for ESZ22_FUT_CME. Unique request ID: 10 | 2022-11-18 13:50:48.753
Removing historical data download ID 10. | 2022-11-18 13:50:48.753
Real-time market depth file updates started for ESZ22_FUT_CME | 2022-11-18 13:50:48.753
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ22_FUT_CME.2022-11-18.depth | 2022-11-18 13:50:48.757
Triggering next historical data download in queue. | 2022-11-18 13:50:48.757
No download requests in the queue to start downloads for. | 2022-11-18 13:50:48.757
Socket (5) | Socket gracefully closed by remote side. | 2022-11-18 13:50:48.783
Socket (5) | Closed. | 2022-11-18 13:50:48.783
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ22_FUT_CME.2022-11-18.depth | 2022-11-18 13:50:49.122
HD Request # 9 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc | 2022-11-18 13:50:53.737
HD Request # 9 | Download start date-time: 2022-11-18 13:50:40.000000. File last date-time: 2022-11-18 13:50:40.462000 | 2022-11-18 13:50:53.737
HD Request # 9 | Using server: ds13-3.sierracharts.com port 10149 | 2022-11-18 13:50:53.737
Socket (5) | Creating socket. | 2022-11-18 13:50:53.738
Socket (5) | New receive buffer size: 5242880 | 2022-11-18 13:50:53.738
Socket (5) | Connecting to IP: 162.251.232.235. | 2022-11-18 13:50:53.738
HD Request # 9 | Setting DTC encoding to Binary VLS | 2022-11-18 13:50:53.893
HD Request # 9 | Sending historical data logon request message. | 2022-11-18 13:50:53.893
HD Request # 9 | Requesting Intraday data. Start date-time: 2022-11-18 13:50:40. Record interval: 0. Symbol: ADR-NYSE | 2022-11-18 13:50:54.662
HD Request # 9 | Decompressing data. | 2022-11-18 13:50:54.738
HD Request # 9 | Receiving Intraday data for ADR-NYSE starting at 2022-11-18 13:50:40.000000 | 2022-11-18 13:50:54.739
Socket (5) | CloseSocket call. | 2022-11-18 13:50:54.739
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:50:54.739
Historical data download thread signaled to stop. | 2022-11-18 13:50:54.739
HD Request # 9 | Timestamp of first Intraday data file record written: 2022-11-18 13:50:41.000000. | 2022-11-18 13:50:54.740
HD Request # 9 | Received 12 Intraday data records from 2022-11-18 13:50:40.000000 to 2022-11-18 13:50:51.000000 (11.0 seconds) and wrote 11 records for ADR-NYSE | 2022-11-18 13:50:54.740
HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2022-11-18 13:50:51.000000 | 2022-11-18 13:50:54.752
Added 6 Time and Sales records to Intraday data file for ADR-NYSE after download. | 2022-11-18 13:50:54.752
HD Request # 9 | Completion time: 1s. | 2022-11-18 13:50:54.752
HD Request # 9 | Intraday data download complete for ADR-NYSE. Unique request ID: 8 | 2022-11-18 13:50:54.752
Removing historical data download ID 8. | 2022-11-18 13:50:54.752
Real-time Intraday chart data file updates started for ADR-NYSE | 2022-11-18 13:50:54.752
Intraday chart data file opened for ADR-NYSE | 2022-11-18 13:50:54.752
HD Request # 9 | Enabling Intraday chart updating for symbol. | 2022-11-18 13:50:54.752
Triggering next historical data download in queue. | 2022-11-18 13:50:54.752
HD Request # 10 | Downloading Intraday chart data for ESZ22_FUT_CME to the file ESZ22_FUT_CME.scid. Service: cme | 2022-11-18 13:50:54.752
HD Request # 10 | Download start date-time: 2022-11-18 13:49:17.000000. File last date-time: 2022-11-18 13:49:17.516018 | 2022-11-18 13:50:54.753
HD Request # 10 | Using server: ds21.sierracharts.com port 10150 | 2022-11-18 13:50:54.753
Socket (6) | Creating socket. | 2022-11-18 13:50:54.753
Socket (6) | New receive buffer size: 5242880 | 2022-11-18 13:50:54.753
Socket (6) | Connecting to IP: 216.1.90.129. | 2022-11-18 13:50:54.753
Socket (5) | Socket gracefully closed by remote side. | 2022-11-18 13:50:54.814
Socket (5) | Closed. | 2022-11-18 13:50:54.814
HD Request # 10 | Setting DTC encoding to Binary VLS | 2022-11-18 13:50:54.835
HD Request # 10 | Sending historical data logon request message. | 2022-11-18 13:50:54.835
HD Request # 10 | Requesting Intraday data. Start date-time: 2022-11-18 13:49:17. Record interval: 0. Symbol: ESZ22 | 2022-11-18 13:50:55.382
HD Request # 10 | Decompressing data. | 2022-11-18 13:50:55.416
HD Request # 10 | Receiving Intraday data for ESZ22_FUT_CME starting at 2022-11-18 13:49:17.335000 | 2022-11-18 13:50:55.417
Socket (6) | CloseSocket call. | 2022-11-18 13:50:55.417
Socket (6) | Shutdown started. Waiting for graceful close. | 2022-11-18 13:50:55.417
Historical data download thread signaled to stop. | 2022-11-18 13:50:55.417
HD Request # 10 | Timestamp of first Intraday data file record written: 2022-11-18 13:49:18.503000. | 2022-11-18 13:50:55.417
HD Request # 10 | Received 575 Intraday data records from 2022-11-18 13:49:17.335000 to 2022-11-18 13:50:51.337000 (94.0 seconds) and wrote 553 records for ESZ22_FUT_CME | 2022-11-18 13:50:55.417
HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2022-11-18 13:50:51.337000 | 2022-11-18 13:50:55.422
Added 1 Time and Sales records to Intraday data file for ESZ22_FUT_CME after download. | 2022-11-18 13:50:55.422
HD Request # 10 | Completion time: 1s. | 2022-11-18 13:50:55.422
HD Request # 10 | Intraday data download complete for ESZ22_FUT_CME. Unique request ID: 9 | 2022-11-18 13:50:55.422
Removing historical data download ID 9. | 2022-11-18 13:50:55.422
Real-time Intraday chart data file updates started for ESZ22_FUT_CME | 2022-11-18 13:50:55.422
Intraday chart data file opened for ESZ22_FUT_CME | 2022-11-18 13:50:55.422
HD Request # 10 | Enabling Intraday chart updating for symbol. | 2022-11-18 13:50:55.422
Triggering next historical data download in queue. | 2022-11-18 13:50:55.422
No download requests in the queue to start downloads for. | 2022-11-18 13:50:55.422
Socket (6) | Socket gracefully closed by remote side. | 2022-11-18 13:50:55.452
Socket (6) | Closed. | 2022-11-18 13:50:55.452
Opened cached Intraday file: C:\SierraChart\Data\ADR-NYSE.scid. Thread ID: 11208 | 2022-11-18 13:50:56.938
Opened cached Intraday file: C:\SierraChart\Data\ESZ22_FUT_CME.scid. Thread ID: 11208 | 2022-11-18 13:50:56.938
Added historical Market depth data request for ESZ22_FUT_CME to the queue. | 2022-11-18 15:49:11.284
Market depth data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-11-18 15:49:11.284
Triggering next historical data download in queue. | 2022-11-18 15:49:11.284
HD Request # 11 | Downloading Market depth data for ESZ22_FUT_CME. Service: cme.marketdepth. | 2022-11-18 15:49:11.285
HD Request # 11 | Download start date-time: 2022-10-29 15:49:11.000000. | 2022-11-18 15:49:11.289
HD Request # 11 | Using server: ds23.sierracharts.com port 10150 | 2022-11-18 15:49:11.289
Socket (5) | Creating socket. | 2022-11-18 15:49:11.387
Socket (5) | New receive buffer size: 5242880 | 2022-11-18 15:49:11.387
Socket (5) | Connecting to IP: 142.215.18.103. | 2022-11-18 15:49:11.387
HD Request # 11 | Setting DTC encoding to Binary VLS | 2022-11-18 15:49:11.495
HD Request # 11 | Sending historical data logon request message. | 2022-11-18 15:49:11.495
HD Request # 11 | Requesting market depth data. Start date-time: 2022-10-29 15:49:11. Symbol: ESZ22 | 2022-11-18 15:49:12.071
HD Request # 11 | Decompressing data. | 2022-11-18 15:49:12.121
HD Request # 11 | Receiving market depth data for ESZ22_FUT_CME starting at 2022-10-30 23:03:06.495260 | 2022-11-18 15:49:12.238
HD Request # 11 | Truncating file to starting date-time of 2022-10-30 23:03:06.495260. | 2022-11-18 15:49:12.239
HD Request # 11 | Error jumping to date-time during truncate. Error: There are no records in the file. | 2022-11-18 15:49:12.239
HD Request # 11 | Timestamp of first market depth data file record written: 2022-10-30 23:03:06.495260. | 2022-11-18 15:49:12.510
ESZ22_FUT_CME [CBV][M] 3 Min #11 | Reloading chart. | 2022-11-18 15:49:50.638
ESZ22_FUT_CME [CBV][M] 3 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 09:09:00. Next Bar Date Time: 2022-11-14 09:00:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 15:49:58.843
ESZ22_FUT_CME [CBV][M] 3 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-14 11:15:00. Next Bar Date Time: 2022-11-14 11:03:00. Filename: ESZ22_FUT_CME.scid | 2022-11-18 15:49:58.909
Loading market depth data. | 2022-11-18 15:49:59.880
Loaded depth data records for ESZ22_FUT_CME 2022-11-18 from 2022-11-17 23:21:42.023000 to 2022-11-18 09:49:09.063000. | 2022-11-18 15:50:00.115
Historical Market depth data request for ESZ22_FUT_CME is discarded because a matching download is in progress and the new one is not for earlier data. | 2022-11-18 15:50:34.413
File >> Disconnect selected. | 2022-11-18 15:50:43.144
HD Request # 11 | Active download canceled. | 2022-11-18 15:50:43.144
Historical data download thread signaled to stop. | 2022-11-18 15:50:43.144
Socket (5) | CloseSocket call. | 2022-11-18 15:50:43.144
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-11-18 15:50:43.144
HD Request # 11 | Received 14820667 Market depth data records from 2022-10-30 23:03:06.495260 to 2022-11-04 18:58:14.537000 (4.8 days) and wrote 14820667 records for ESZ22_FUT_CME | 2022-11-18 15:50:43.145
HD Request # 11 | Completion time: 1m 32s. | 2022-11-18 15:50:43.148
HD Request # 11 | Market depth data download complete for ESZ22_FUT_CME. Unique request ID: 11 | 2022-11-18 15:50:43.148
Removing historical data download ID 11. | 2022-11-18 15:50:43.148
Real-time market depth file updates started for ESZ22_FUT_CME | 2022-11-18 15:50:43.148
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ22_FUT_CME.2022-11-18.depth | 2022-11-18 15:50:43.148
Triggering next historical data download in queue. | 2022-11-18 15:50:43.148
Teton CME Order Routing | Waiting for socket receive thread to end | 2022-11-18 15:50:43.153
DTC Client socket (1) | CloseSocket call. | 2022-11-18 15:50:43.153
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-11-18 15:50:43.153
DTC Client socket (1) | Max send buffer size during socket life: 236 | 2022-11-18 15:50:43.153
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-11-18 15:50:43.153
SC Data - All Services | Waiting for socket receive thread to end | 2022-11-18 15:50:43.153
DTC Client socket (4) | CloseSocket call. | 2022-11-18 15:50:43.154
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-11-18 15:50:43.154
SC Data - All Services | Disconnected from the server. | 2022-11-18 15:50:43.154
SC Data - All Services | Waiting for socket receive thread to end | 2022-11-18 15:50:43.154
DTC Client socket (2) | CloseSocket call. | 2022-11-18 15:50:43.154
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-11-18 15:50:43.154
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-11-18 15:50:43.154
DTC Client socket (3) | CloseSocket call. | 2022-11-18 15:50:43.154
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-11-18 15:50:43.154
SC DTC Data with Market Depth | Disconnected from the server. | 2022-11-18 15:50:43.154
Teton CME Order Routing | Disconnected. | 2022-11-18 15:50:43.154
No download requests in the queue to start downloads for. | 2022-11-18 15:50:43.154
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-11-18 15:50:43.197
DTC Client socket (1) | Closed. | 2022-11-18 15:50:43.197
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-11-18 15:50:43.206
DTC Client socket (2) | Closed. | 2022-11-18 15:50:43.206
Teton CME Order Routing | Firm: Phillip Capital | 2022-11-18 15:50:47.380
Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11089 | 2022-11-18 15:50:47.380
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-11-18 15:50:47.471
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-11-18 15:50:47.471
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-11-18 15:50:47.471
Teton CME Order Routing | Network connection to server complete. | 2022-11-18 15:50:47.519
Teton CME Order Routing | Starting socket receive thread. | 2022-11-18 15:50:47.519
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-11-18 15:50:47.519
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-11-18 15:50:47.658
Teton CME Order Routing | Sending logon request message. | 2022-11-18 15:50:47.658
Teton CME Order Routing | Received logon response. | 2022-11-18 15:50:48.211
Teton CME Order Routing | Server Name: SC DTC Server. Build=43909M. | 2022-11-18 15:50:48.211
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 15:50:48.211
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-11-18 15:50:48.211
Teton CME Order Routing | Trading is supported. | 2022-11-18 15:50:48.211
Teton CME Order Routing | Order cancel and replace is supported. | 2022-11-18 15:50:48.211
Teton CME Order Routing | OCO Orders supported. | 2022-11-18 15:50:48.211
Teton CME Order Routing | Bracket Orders supported. | 2022-11-18 15:50:48.211
Teton CME Order Routing | Connected to server complete. | 2022-11-18 15:50:48.211
Triggering next historical data download in queue. | 2022-11-18 15:50:48.212
Subscribing to symbol for symbol alert. VXH22-CFE | 2022-11-18 15:50:48.212
Mapping VXH22-CFE to VXH22_FUT_CFE. Service code: cfe_exchange.data | 2022-11-18 15:50:48.212
Using symbol data fast lookup vector | 2022-11-18 15:50:48.212
SC Data - All Services | Starting real-time market data updates for: VXH22-CFE (VXH22_FUT_CFE). ID: 1 Service code: cfe_exchange.data | 2022-11-18 15:50:48.212
SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 443 | 2022-11-18 15:50:48.212
SC Data - All Services | Requesting security definition data for: VXH22-CFE (VXH22_FUT_CFE). ID: 1 | 2022-11-18 15:50:48.212
Updated verified funded futures trading account ending date to: 2022-12-18 15:50:48 | 2022-11-18 15:50:48.212
DTC Client socket (2) | Creating socket. | 2022-11-18 15:50:48.213
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-11-18 15:50:48.213
DTC Client socket (2) | Connecting to IP: 38.65.8.115. | 2022-11-18 15:50:48.213
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-11-18 15:50:48.224
No download requests in the queue to start downloads for. | 2022-11-18 15:50:48.224
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: VXH22-CFE | 2022-11-18 15:50:48.255
Teton CME Order Routing | Received security definition for symbol VXH22-CFE | 2022-11-18 15:50:48.255
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-11-17 19:26:03.318840 | 2022-11-18 15:50:48.260
Updated verified funded futures trading account ending date to: 2022-12-18 15:50:48 | 2022-11-18 15:50:48.266
SC Data - All Services | Network connection to server complete. | 2022-11-18 15:50:48.270
SC Data - All Services | Starting socket receive thread. | 2022-11-18 15:50:48.270
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-11-18 15:50:48.270
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=7PV1252 | 2022-11-18 15:50:48.312
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-11-18 15:50:48.350
SC Data - All Services | Sending logon request message. | 2022-11-18 15:50:48.350
Mapping ESZ22_FUT_CME to ESZ22. Service code: cme | 2022-11-18 15:50:48.368
SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME (ESZ22). ID: 2 Service code: cme | 2022-11-18 15:50:48.368
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-11-18 15:50:48.368
SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME (ESZ22). ID: 2 | 2022-11-18 15:50:48.368
Requesting market depth updates for: ESZ22_FUT_CME if supported. | 2022-11-18 15:50:48.368
Separate subscription for market depth updates not supported. ESZ22_FUT_CME | 2022-11-18 15:50:48.368
Added historical Intraday data request for ESZ22_FUT_CME to the queue. | 2022-11-18 15:50:48.368
Intraday data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-11-18 15:50:48.368
Triggering next historical data download in queue. | 2022-11-18 15:50:48.368
DTC Client socket (6) | Creating socket. | 2022-11-18 15:50:48.369
DTC Client socket (6) | New receive buffer size: 5242880 | 2022-11-18 15:50:48.369
DTC Client socket (6) | Connecting to IP: 142.215.18.103. | 2022-11-18 15:50:48.369
Delaying start of download for ESZ22_FUT_CME. | 2022-11-18 15:50:48.384
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ22_FUT_CME | 2022-11-18 15:50:48.418
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-11-18 15:50:48.418
SC Data - All Services | Network connection to server complete. | 2022-11-18 15:50:48.425
SC Data - All Services | Starting socket receive thread. | 2022-11-18 15:50:48.425
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-11-18 15:50:48.425
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-11-18 15:50:48.490
SC Data - All Services | Sending logon request message. | 2022-11-18 15:50:48.490
SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-NYSE. ID: 3 Service code: statscalc | 2022-11-18 15:50:48.642
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2022-11-18 15:50:48.642
SC DTC Data with Market Depth | Requesting security definition data for: ADR-NYSE. ID: 3 | 2022-11-18 15:50:48.642
Added historical Intraday data request for ADR-NYSE to the queue. | 2022-11-18 15:50:48.642
Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'. | 2022-11-18 15:50:48.642
Triggering next historical data download in queue. | 2022-11-18 15:50:48.642
DTC Client socket (7) | Creating socket. | 2022-11-18 15:50:48.740
DTC Client socket (7) | New receive buffer size: 5242880 | 2022-11-18 15:50:48.740
DTC Client socket (7) | Connecting to IP: 142.215.18.104. | 2022-11-18 15:50:48.740
SC DTC Data with Market Depth | Network connection to server complete. | 2022-11-18 15:50:48.796
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-11-18 15:50:48.796
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-11-18 15:50:48.796
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-11-18 15:50:48.874
SC DTC Data with Market Depth | Sending logon request message. | 2022-11-18 15:50:48.874
SC Data - All Services | Received logon response. | 2022-11-18 15:50:49.050
SC Data - All Services | Server Name: SC Realtime Server. | 2022-11-18 15:50:49.050
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 15:50:49.050
SC Data - All Services | Successfully connected. | 2022-11-18 15:50:49.050
SC Data - All Services | Trading is not supported. | 2022-11-18 15:50:49.050
SC Data - All Services | Restarting real-time data updates for symbol: VXH22-CFE -> VXH22_FUT_CFE | 2022-11-18 15:50:49.050
SC Data - All Services | Real-time data for symbol VXH22-CFE is currently unavailable. | 2022-11-18 15:50:49.207
SC Data - All Services | Received security definition for symbol VXH22-CFE | 2022-11-18 15:50:49.207
SC Data - All Services | Received logon response. | 2022-11-18 15:50:49.273
SC Data - All Services | Server Name: SC Realtime Server. | 2022-11-18 15:50:49.273
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 15:50:49.273
SC Data - All Services | Successfully connected. | 2022-11-18 15:50:49.273
SC Data - All Services | Trading is not supported. | 2022-11-18 15:50:49.273
Added historical Market depth data request for ESZ22_FUT_CME to the queue. | 2022-11-18 15:50:49.273
Market depth data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-11-18 15:50:49.273
Triggering next historical data download in queue. | 2022-11-18 15:50:49.273
SC Data - All Services | Restarting real-time data updates for symbol: ESZ22_FUT_CME -> ESZ22. Market Depth data restarted. | 2022-11-18 15:50:49.273
HD Request # 12 | Downloading Market depth data for ESZ22_FUT_CME. Service: cme.marketdepth. | 2022-11-18 15:50:49.273
HD Request # 12 | Download start date-time: 2022-11-18 15:50:43.153695. | 2022-11-18 15:50:49.274
HD Request # 12 | Using server: ds26.sierracharts.com port 10149 | 2022-11-18 15:50:49.274
Socket (8) | Creating socket. | 2022-11-18 15:50:49.368
Socket (8) | New receive buffer size: 5242880 | 2022-11-18 15:50:49.368
Socket (8) | Connecting to IP: 142.215.18.107. | 2022-11-18 15:50:49.368
SC Data - All Services | Received security definition for symbol ESZ22_FUT_CME | 2022-11-18 15:50:49.428
SC Data - All Services | Market Depth data has been rejected for symbol: ESZ22_FUT_CME. Not authorized for market depth. | 2022-11-18 15:50:49.428
HD Request # 12 | Setting DTC encoding to Binary VLS | 2022-11-18 15:50:49.485
HD Request # 12 | Sending historical data logon request message. | 2022-11-18 15:50:49.485
SC DTC Data with Market Depth | Received logon response. | 2022-11-18 15:50:49.563
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-11-18 15:50:49.563
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-11-18 15:50:49.563
SC DTC Data with Market Depth | Successfully connected. | 2022-11-18 15:50:49.563
SC DTC Data with Market Depth | Trading is not supported. | 2022-11-18 15:50:49.563
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NYSE | 2022-11-18 15:50:49.563
SC DTC Data with Market Depth | Received security definition for symbol ADR-NYSE | 2022-11-18 15:50:49.719
HD Request # 12 | Requesting market depth data. Start date-time: 2022-11-18 15:50:43. Symbol: ESZ22 | 2022-11-18 15:50:50.064
HD Request # 12 | Decompressing data. | 2022-11-18 15:50:50.114
HD Request # 12 | Receiving market depth data for ESZ22_FUT_CME starting at 2022-11-18 15:50:43.154000 | 2022-11-18 15:50:50.119
Socket (8) | CloseSocket call. | 2022-11-18 15:50:50.120
Socket (8) | Shutdown started. Waiting for graceful close. | 2022-11-18 15:50:50.120
Historical data download thread signaled to stop. | 2022-11-18 15:50:50.120
HD Request # 12 | Timestamp of first market depth data file record written: 2022-11-18 15:50:43.154000. | 2022-11-18 15:50:50.120
HD Request # 12 | Received 1188 Market depth data records from 2022-11-18 15:50:43.154000 to 2022-11-18 15:50:47.645000 (4.5 seconds) and wrote 1188 records for ESZ22_FUT_CME | 2022-11-18 15:50:50.120
HD Request # 12 | Completion time: 1s. | 2022-11-18 15:50:50.120
HD Request # 12 | Market depth data download complete for ESZ22_FUT_CME. Unique request ID: 15 | 2022-11-18 15:50:50.120
Removing historical data download ID 15. | 2022-11-18 15:50:50.120
Real-time market depth file updates started for ESZ22_FUT_CME | 2022-11-18 15:50:50.120
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ22_FUT_CME.2022-11-18.depth | 2022-11-18 15:50:50.125
Triggering next historical data download in queue. | 2022-11-18 15:50:50.126
No download requests in the queue to start downloads for. | 2022-11-18 15:50:50.126
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ22_FUT_CME.2022-11-18.depth | 2022-11-18 15:50:50.153
Socket (8) | Socket gracefully closed by remote side. | 2022-11-18 15:50:50.183
Socket (8) | Closed. | 2022-11-18 15:50:50.183
HD Request # 13 | Downloading Intraday chart data for ESZ22_FUT_CME to the file ESZ22_FUT_CME.scid. Service: cme | 2022-11-18 15:50:54.640
HD Request # 13 | Download start date-time: 2022-11-18 15:50:40.000000. File last date-time: 2022-11-18 15:50:40.794000 | 2022-11-18 15:50:54.640
HD Request # 13 | Using server: ds23.sierracharts.com port 10149 | 2022-11-18 15:50:54.641
Socket (8) | Creating socket. | 2022-11-18 15:50:54.641
Socket (8) | New receive buffer size: 5242880 | 2022-11-18 15:50:54.641
Socket (8) | Connecting to IP: 142.215.18.103. | 2022-11-18 15:50:54.641
HD Request # 13 | Setting DTC encoding to Binary VLS | 2022-11-18 15:50:54.756
HD Request # 13 | Sending historical data logon request message. | 2022-11-18 15:50:54.756
HD Request # 13 | Requesting Intraday data. Start date-time: 2022-11-18 15:50:40. Record interval: 0. Symbol: ESZ22 | 2022-11-18 15:50:55.335
HD Request # 13 | Decompressing data. | 2022-11-18 15:50:55.416
HD Request # 13 | Receiving Intraday data for ESZ22_FUT_CME starting at 2022-11-18 15:50:40.648000 | 2022-11-18 15:50:55.417
Socket (8) | CloseSocket call. | 2022-11-18 15:50:55.418
Socket (8) | Shutdown started. Waiting for graceful close. | 2022-11-18 15:50:55.418
Historical data download thread signaled to stop. | 2022-11-18 15:50:55.418
HD Request # 13 | Timestamp of first Intraday data file record written: 2022-11-18 15:50:41.109000. | 2022-11-18 15:50:55.418
HD Request # 13 | Received 240 Intraday data records from 2022-11-18 15:50:40.648000 to 2022-11-18 15:50:51.033000 (10.4 seconds) and wrote 233 records for ESZ22_FUT_CME | 2022-11-18 15:50:55.419
HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2022-11-18 15:50:51.033000 | 2022-11-18 15:50:55.428
Added 46 Time and Sales records to Intraday data file for ESZ22_FUT_CME after download. | 2022-11-18 15:50:55.428
HD Request # 13 | Completion time: 1s. | 2022-11-18 15:50:55.428
HD Request # 13 | Intraday data download complete for ESZ22_FUT_CME. Unique request ID: 13 | 2022-11-18 15:50:55.428
Removing historical data download ID 13. | 2022-11-18 15:50:55.428
Real-time Intraday chart data file updates started for ESZ22_FUT_CME | 2022-11-18 15:50:55.428
Intraday chart data file opened for ESZ22_FUT_CME | 2022-11-18 15:50:55.428
HD Request # 13 | Enabling Intraday chart updating for symbol. | 2022-11-18 15:50:55.428
Triggering next historical data download in queue. | 2022-11-18 15:50:55.428
HD Request # 14 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc | 2022-11-18 15:50:55.428
HD Request # 14 | Download start date-time: 2022-11-18 15:50:40.000000. File last date-time: 2022-11-18 15:50:40.711002 | 2022-11-18 15:50:55.429
HD Request # 14 | Using server: ds12.sierracharts.com port 10150 | 2022-11-18 15:50:55.429
Socket (9) | Creating socket. | 2022-11-18 15:50:55.429
Socket (9) | New receive buffer size: 5242880 | 2022-11-18 15:50:55.429
Socket (9) | Connecting to IP: 142.215.18.104. | 2022-11-18 15:50:55.429
Socket (8) | Socket gracefully closed by remote side. | 2022-11-18 15:50:55.467
Socket (8) | Closed. | 2022-11-18 15:50:55.467
HD Request # 14 | Setting DTC encoding to Binary VLS | 2022-11-18 15:50:55.538
HD Request # 14 | Sending historical data logon request message. | 2022-11-18 15:50:55.538
Opened cached Intraday file: C:\SierraChart\Data\ESZ22_FUT_CME.scid. Thread ID: 11208 | 2022-11-18 15:50:55.814
HD Request # 14 | Requesting Intraday data. Start date-time: 2022-11-18 15:50:40. Record interval: 0. Symbol: ADR-NYSE | 2022-11-18 15:50:56.118
HD Request # 14 | Decompressing data. | 2022-11-18 15:50:56.170
HD Request # 14 | Receiving Intraday data for ADR-NYSE starting at 2022-11-18 15:50:40.000000 | 2022-11-18 15:50:56.171
Socket (9) | CloseSocket call. | 2022-11-18 15:50:56.172
Socket (9) | Shutdown started. Waiting for graceful close. | 2022-11-18 15:50:56.172
Historical data download thread signaled to stop. | 2022-11-18 15:50:56.172
HD Request # 14 | Timestamp of first Intraday data file record written: 2022-11-18 15:50:41.000000. | 2022-11-18 15:50:56.172
HD Request # 14 | Received 13 Intraday data records from 2022-11-18 15:50:40.000000 to 2022-11-18 15:50:52.000000 (12.0 seconds) and wrote 12 records for ADR-NYSE | 2022-11-18 15:50:56.172
HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2022-11-18 15:50:52.000000 | 2022-11-18 15:50:56.184
Added 10 Time and Sales records to Intraday data file for ADR-NYSE after download. | 2022-11-18 15:50:56.184
HD Request # 14 | Completion time: 1s. | 2022-11-18 15:50:56.185
HD Request # 14 | Intraday data download complete for ADR-NYSE. Unique request ID: 14 | 2022-11-18 15:50:56.185
Removing historical data download ID 14. | 2022-11-18 15:50:56.185
Real-time Intraday chart data file updates started for ADR-NYSE | 2022-11-18 15:50:56.185
Intraday chart data file opened for ADR-NYSE | 2022-11-18 15:50:56.185
HD Request # 14 | Enabling Intraday chart updating for symbol. | 2022-11-18 15:50:56.185
Triggering next historical data download in queue. | 2022-11-18 15:50:56.185
No download requests in the queue to start downloads for. | 2022-11-18 15:50:56.185
Socket (9) | Socket gracefully closed by remote side. | 2022-11-18 15:50:56.225
Socket (9) | Closed. | 2022-11-18 15:50:56.225
Opened cached Intraday file: C:\SierraChart\Data\ADR-NYSE.scid. Thread ID: 11208 | 2022-11-18 15:51:00.860
[2022-11-18 17:26:52]
John - SC Support - Posts: 38835
Sorry, since you said you had Market Depth displaying, we did not check the basics. You do not have an exchange active that includes Market Depth.
You can change your exchange selections at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
If you just need Market Depth data for the ES (or other products that are traded on the CME exchange) then we would recommend adding the "CME with Market Depth for non-professional Trading accounts" exchange to what you already have active (cost is $11.00 per month). This way you will continue to have access to the data from all of the CME Group and give you Market Depth data for all products traded on the CME exchange.
Otherwise, if you need Market Depth for all products from the CME Group, then you would want to deactivate your current selection and then activate the "Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for non-professional Trading accounts" (cost is $33.00 per month).
Just keep in mind that the exchange do not give refunds, nor is the cost pro-rated, so you will pay the full amount for the remainder of this month and you will not get a refund for the already activated exchanges.
