Date/Time: Fri, 21 Mar 2025 07:33:03 +0000
sierra chart not working properly
View Count: 374
[2022-11-18 12:27:34] |
User411320 - Posts: 306 |
Attached is a photo showing a gap in my chart. it's like that for all my charts and symbols. I've reloaded and recalculated and disconnected data and connected
Private File |
[2022-11-18 12:42:03] |
Sierra_Chart Engineering - Posts: 18875 |
Follow the instructions here to download the missing data: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-18 14:03:38] |
that worked thank you
