Date/Time: Fri, 21 Mar 2025 07:20:42 +0000
Elliott Waves draw tools
View Count: 435
[2022-11-18 11:19:53] |
User266447 - Posts: 270 |
Does SC have a tool to draw Elliott Waves on a chart? For example, for MT4 platforms there is outside software that can be uploaded on MT4 and it helps to draw Elliott Waves on a chart. Maybe SC has a tool that helps draw Elliot Waves? |
[2022-11-18 11:44:09] |
Do we have MBO date for EUREX - DAX in particular? in package 12?
[2022-11-18 16:02:36] |
John - SC Support - Posts: 38835 |
For example, for MT4 platforms there is outside software that can be uploaded on MT4 and it helps to draw Elliott Waves on a chart. Maybe SC has a tool that helps draw Elliot Waves? We do not have any thing built-in, but there might be third party developer that has something. Be sure to search the Internet to see. Do we have MBO date for EUREX - DAX in particular? in package 12?
Yes, this is available, but you need to activate the EUREX EOBI exchange that is part of the Denali Exchange Data feed. Follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* And also make sure you go through the instructions at the following link to ensure you have everything setup properly for the MBO data: Market By Order Data: Step-by-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
