Date/Time: Fri, 21 Mar 2025 07:18:12 +0000
Denali data
View Count: 376
[2022-11-18 09:10:03] |
OriolCasas - Posts: 189 |
Hello, I am about to buy data. I trade ES and CL only. But I also use internals NYSE TICK AND NISS-NYSE. What data do I have to purchase for that? For CL and ES buying CME and NYMEX should be enough. But for internals do I have to purchase the all CME markets option? Thank you |
[2022-11-18 12:41:07] |
Sierra_Chart Engineering - Posts: 18875 |
Market statistics, are included with all Service Packages: Sierra Chart Market Statistics For the CME data, you will need Service Package 10 or 11. And then activate the exchanges that you need. Instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
