Date/Time: Fri, 21 Mar 2025 07:38:55 +0000
Numbers Bars displays zeroes
View Count: 531
[2022-11-18 08:11:09] |
User729875 - Posts: 1 |
Recently, when I open Sierra Chart and my Chartbook, Numbers Bars study only displays zeros on the past values and starts filling with values from the moment when the chart is open. Do not charge past values. My actual Sierra Chart version is 2393. |
![]() Attachment Deleted. |
[2022-11-18 15:02:07] |
Sierra_Chart Engineering - Posts: 18875 |
This has to do with CQG data. Sierra Chart does not support tick by tick data from CQG for CME and EUREX. You need to use the Denali Data Feed. Instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
