Date/Time: Fri, 21 Mar 2025 07:41:36 +0000
Heatmap Chart Issue
View Count: 583
[2022-11-17 17:36:47]
User148596 - Posts: 217
Hi, I have a heatmap chart that is having issues. Everything was working fine with it until a couple days ago. Now it's not updating and the price isn't moving. I tried reloading and recalculating the chart and that didn't change anything. The symbol and session times are all correct. Any thoughts on what could be causing this?
[2022-11-17 18:47:43]
John - SC Support - Posts: 38835
Start by duplicating the chart and then remove all studies and see if the underlying bars are updating properly or not.
If they are not updating then follow these instructions to get us your Message Log:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
