Date/Time: Fri, 21 Mar 2025 07:54:23 +0000
Bid & Ask depth bars: Cumulative Difference, start point
View Count: 421
[2022-11-17 16:08:20] |
User198125 - Posts: 38 |
Hello SC, Can you tell me, for the study: "Bid & Ask depth bars", when we select Calculation mode = "Cumulative Difference (x - y)" option, what is the start for the first data point? Is the first cumulative point the first data point that is loaded or does it reset at the start of a new day? Thank you Date Time Of Last Edit: 2022-11-17 16:58:35
[2022-11-17 18:34:40] |
John - SC Support - Posts: 38835 |
The start of the cumulative sum is the first data point in the chart. It does not reset with each trading day.
