Date/Time: Fri, 21 Mar 2025 07:25:04 +0000
High single trades study
View Count: 402
[2022-11-17 15:17:52] |
User274939 - Posts: 13 |
Hello guys, I have spent a lot of time searching for a study but with no success unfortunately. I need your help. Is there any study for sierrachart that "marks" high volume trades. Bear in mind I am not looking to see the cumulative volume above a threshold. I would like to see on my renko chart (a dot for example) that on a certain price was executed 1 trade for 50 lots. Appreciate all the work you do! Regards |
[2022-11-17 15:22:26] |
Sierra_Chart Engineering - Posts: 18875 |
Yes here is the study: Large Volume Trade Indicator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-17 15:23:27
[2022-11-17 15:34:36] |
Can I "isolate" the rest of the orders and to see only the single trades above the "threshold". For example if I put Volume Threshold to 30 as I understand it will show me single trades above 30 but also accumulated trades with total of 30 lots. So if there are 3 single trades x 10 lots it will print a dot. If I am right I would like to see printed dot only once there is at least 30 lot trade. If there is any way to setup the study I would be more than happy. Thanks in advance! Regards |
[2022-11-17 18:10:52] |
John - SC Support - Posts: 38835 |
We are not sure what you are asking, as it sounds like what the study already does. You will only get the notice when a single trade is greater than or equal to the Input you have set. The one thing we want to point out is that you will not get a notice when there are 3 trades of 10 lots each, as the system has no way of knowing that these were part of a single trade. The only way to "solve" this is to enable the option for Chart >> Chart Settings >> Chart Data >> Combine Trades into Original Summary Trade. Refer to the information here: Chart Settings: Combine Trades into Original Summary Trade (Data Feed and Exchange Specific) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Setting the above will give you the information that a single trade existed as a total quantity of 30 even if it filled as 3 different trades of 10 lots each. But, it can not give you the information if the person put in the original trades as 3 different trades of 10 lots each. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-17 18:14:55] |
Thank you very much, Jonh! Sorted it out. It works perfect. All I need. Have a good day! Regards |
