Date/Time: Wed, 23 Sep 2026 19:55:01 +0000
Black Screen
View Count: 857
[2022-11-17 14:13:12]
User120955 - Posts: 7
I've previously had my bid x ask order flow template up and showing, I then tried to zoom the chart out and the chart went completely black, and now I'm unable to see anything. How can I fix this issue? https://www.sierrachart.com/image.php?Image=1668694289595.png
[2022-11-17 14:35:32]
Sierra_Chart Engineering - Posts: 24947
Follow the instructions here to reset the scales:
Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales.
[2022-11-17 14:52:25]
I've tried that before reaching out, unfortunately these instructions didn't fix my issue.
[2022-11-17 15:28:07]
Therefore, attach the chart here following these instructions:
[2022-11-17 15:45:47]
im not sure on how to do this, its not working the way im doing the steps, this is the only picture i was able to upload https://www.sierrachart.com/image.php?Image=1668694289595.png
is there anyway i can have someone assist me by taking over my computer?
attachmentChartbook1.Cht - Attached On 2022-11-17 15:43:08 UTC - Size: 4.38 KB - 295 views
[2022-11-17 15:46:44]
this is the file i believe
attachmentBid x Ask Order Flow (1).Cht - Attached On 2022-11-17 15:46:23 UTC - Size: 15.85 KB - 340 views
[2022-11-17 17:21:42]
We will check the Chartbook.
[2022-11-17 17:51:54]
Its okay, my issue has now been resolved. Thank you for your assistance.
[2022-11-17 19:18:51]
That is good, but we see how we can improve the Reset Scales functionality when there is an invalid number for the constant range and that is what we are doing.
Date Time Of Last Edit: 2022-11-17 19:19:03
[2022-11-17 20:39:07]
okay great, anything will help to avoid this issue again, i did notice my chart mess up when i select the constant range scale option, so i'm going to avoid doing so.
