Date/Time: Tue, 26 Nov 2024 20:13:21 +0000
2 minutes or 3 minutes or range 2xx, 3xx tick chart?
View Count: 1678
[2014-05-26 13:14:58] |
dez - Posts: 45 |
Is it possible to get the sierra c PACK3 2 or 3 minute chart? and whether it is possible to make a tick range chart example of .23 or 300 tick chart .. is there such a setting? because I'm looking at studies but that no, thank you
[2014-05-28 08:15:51] |
Yes this is supported. What symbol did you want to do this on? Here is the documentation: http://www.sierrachart.com/index.php?l=doc/doc_KeyboardCommands.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-18 21:00:10] |
dez - Posts: 45 |
I apologize but I can not not do it ... just offering 1,5.10.15.30.60.4 h etc. ... not impossible to make a tick chart or 2 or 3 min chart ... do you have a video help?
[2014-06-19 20:11:50] |
You need to select Chart >> Chart Settings. Change the Intraday Chart Bar Period >> Bar Period Type and the corresponding setting. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
