Date/Time: Fri, 21 Mar 2025 08:00:06 +0000
Revive Older Chartbook
View Count: 373
[2022-11-17 13:37:23] |
KXRCap - Posts: 64 |
I have a couple of Older Chartbooks that I would like to use. Whats my easiest way to bring those current? Thanks. |
[2022-11-17 17:35:11] |
John - SC Support - Posts: 38835 |
If you can not open them in the current version, then follow the instructions at the following link: Chartbooks (Workspaces): Opening Older Chartbooks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
