Date/Time: Thu, 17 Sep 2026 10:21:15 +0000
Funktion Request: Safe function for modified text on Rays, Lines ...
View Count: 601
[2022-11-17 11:56:54]
WCAP2021 - Posts: 1
I'd would be great to have the possability to save Lines mith modified text
For my drawings I use the same colours for same kind of levels, so I'd would be nice to attach a text and the possability to safe this as Quick Load
Thx Tobias
[2022-11-17 16:53:31]
John - SC Support - Posts: 47917
This can be done.
For some of the drawing tools (Line has this ability), when you edit the Tool Configuration there is an option under the "Label" tab that states Copy Config Name to Text. Therefore, when you save the configuration and give it a name, it will use that configuration name for the text for that drawing. Refer to the section on "Labels >> Copy Config Name to Text" for more information on this, at the following link:
Chart Drawing Tools: Common Tool Configuration Settings and Chart Drawing Properties
Then refer to the instructions for how to create Control Bar buttons that will select a tool and configuration:
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step
