Date/Time: Fri, 21 Mar 2025 10:15:06 +0000
[Programming Help] - Automated Strategy on different Future Options contracts running simultaneously
View Count: 328
[2022-11-17 01:17:07] |
User500500 - Posts: 16 |
Does Sierra give the ability to create an automated 'Study' or System that buys and sells Put Future Options of a specific Strike price? I see a lot of material and threads about setting limit orders to enter a position but did not see any examples where these orders were made for Futures Options. If so, would Sierra allow me to run this strategy simultaneously for different expiration months of the same Symbol (Future)? Thanks, Kevin |
[2022-11-21 15:53:53] |
Sierra_Chart Engineering - Posts: 18875 |
You can certainly create an ACSIL automated trading system that submits an order for a symbol different than the chart which contains the automated trading system. Refer to: Automated Trading From an Advanced Custom Study: Submitting and Managing Orders for Different Symbol and/or Trade Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-21 15:56:07
