Date/Time: Thu, 20 Mar 2025 20:08:42 +0000
[Programming Help] - Daily pivot - number of days defaults to 1 instead of user enabled zero
View Count: 368
[2022-11-16 23:08:35]
vijayrams - Posts: 5
Studies: Daily pivot - number of days defaults to 1 instead of user enabled zero - Request Bug fix help.
Studies: Daily pivot - number of days Study - setting --> number of days to calculate set to zero, by next day, setting will defaults back to '1' by following day, which leaves two lines from previous day, someone has to manually update it. Requires bug fix to save and persist the setting ASIS.
Please fix potential bug to leave the settings saved ASIS, not to reset to other than user settings.
Enhancement Request:
If they could enhance the Daily pivots to include various type of pivots like Floor pivots, Fibonacci pivots etc., that would be very helpful.
Thank you.
imagepivotstudy-bug-2022-11-16 09_21_04-Sierra Chart 2448 ES-NQ-P.jpg / V - Attached On 2022-11-16 23:04:49 UTC - Size: 450.11 KB - 98 views
[2022-11-16 23:26:48]
John - SC Support - Posts: 38831
This has been answered here:
https://www.sierrachart.com/SupportBoard.php?ThreadID=79103
[2022-11-16 23:37:40]
User584084 - Posts: 268
Open the Pivot Points-Daily study. Click the Description button on the Settings and Inputs tab. Scroll down the page to Formula Types. There are 28 types of pivots.
