Date/Time: Thu, 20 Mar 2025 19:55:57 +0000
Volume by price add on TPO - mixed up vs view next column
View Count: 364
[2022-11-16 23:01:59]
vijayrams - Posts: 5
1) Study - Vbp: While adding Volume by price next to TPO profile either it overrides or its not useful, in the past it used to provide an option to display right next to TPO profile, however after the upgrade this setting no longer works, Please review and address.
2) Total mess when you add VbP, it overlays on top of TPO instead of displaying right next, it used to work before perhaps over the period of upgrades it does not work properly, or if there is a hidden setting which makes it work do let me know; please provide fix.
Please refer screen shots with add on mix.
imageVBP-on-tpo-overlay-vs_display-right-next-.jpg / V - Attached On 2022-11-16 23:00:39 UTC - Size: 713.21 KB - 98 views
image2022-11-16 10_59_44-VBProfile_next_TPO-is not visible.png / V - Attached On 2022-11-16 23:00:45 UTC - Size: 322.59 KB - 94 views
[2022-11-16 23:33:47]
John - SC Support - Posts: 38831
This is incredibly strange, as it should be drawn next to the TPO profile, as you are expecting it to do. We just tested this to ensure it is working correctly and it is doing it correctly for us. None of the Inputs should affect how the profiles are drawn, as this is all handled internally in order to ensure that what you are seeing does NOT occur.
Please get us a chartbook with that chart in it so we can take a look at why this is occurring for you. Follow the instructions at the following link to get us the chartbook (if you are duplicating the chart, be sure the duplicate shows the same issue with how the VbP is drawn):
