Date/Time: Fri, 21 Mar 2025 07:33:03 +0000
Correct After Hours :)
View Count: 622
[2022-11-16 22:56:42]
User72965 - Posts: 115
This is from my older Computer which is getting Tired:(
Sending a screen for you to see ~~
Gene :)
https://www.sierrachart.com/image.php?Image=166863934638.png
[2022-11-17 15:31:13]
John - SC Support - Posts: 38835
Please continue to use the same thread that was already started for this. That thread is here:
Alert notifications & N period still not right
[2022-11-18 00:20:15]
Today All N's into over night : However the price cursor
ran about 10 seconds into the day time<> AFTER the N's were up
So not sure it missed any contracts??
Gene getting closer :)
https://www.sierrachart.com/image.php?Image=166873061170.png
https://www.sierrachart.com/image.php?Image=1668730721255.png
https://www.sierrachart.com/image.php?Image=166873077267.png
[2022-11-18 14:59:42]
The Time Scale for a TPO Chart is meaningless apart from the start times that are shown for the TPO. When you use the cursor and highlight a time, it is not really the time that is shown at that point.
Therefore, it looks like you have your issue worked out.
[2022-11-18 16:05:17]
On After Hours Yes John <> After Hours Seem to be o.k. for now
I lost??misplaced my inquire on Alerts for tradeing <> Vocal> Order filled Order cancelled~~
Could you send on it~ I see 28 there ~How do I listen to them;To tell which one I need??
And save them to the chart...
Thx Gene :)
[2022-11-18 17:50:28]
To set the alert for when an order is filled refer to the documentation here:
Global Trade Settings Windows: Play Alert When Order Filled (Global Settings >> General Trade Settings >> Notifications)
And note the documentation above and below for other alert options.
To view the sound associated with an alert or to change it, refer to the information at the following link:
General Settings Window: Configuring Alert Number Instructions
[2022-11-19 22:47:58]
Got no-where with Alerts: See 200 of them ..
Can't play them/So don't get the one I need .
Need to play them to see one I need..
Also is the 10 year note listed in CME??
Seems I Am Getting Crude OIL ON NYMEX ~~
Gene :)
[2022-11-19 22:51:33]
User584084 - Posts: 268
ZN - 10 Year Treasury Note is listed on ECBOT (Chicago Board or Trade)
Date Time Of Last Edit: 2022-11-19 22:53:06
[2022-11-21 14:45:12]
Sierra_Chart Engineering - Posts: 18875
If you are having an issue with alert sounds, refer to:
General Settings Window: Troubleshooting for Alert Sounds That Do Not Play
And also refer to this page regarding Chart and Study alerts:
Study/Chart Alerts And Scanning
Date Time Of Last Edit: 2022-11-21 14:45:32
