Date/Time: Mon, 14 Sep 2026 01:52:47 +0000
Feature request - Drawing objects - individual snap capability
View Count: 574
[2022-11-16 22:22:01]
JohnR - User831573 - Posts: 338
When clicking on a object and selecting snap, it seems to move all points. In my case - 3 (pitchfork) My request is 2 fold.
1 - In the Drawing object popup window - tab of anchors - add another column for each anchor with dropdown options for Snap --> None, Close, High, Low, Nearest H/L.
2 - in popup menu to modify the drawing object, change it to be snap to all points or single, somehow.
JohnR
imageSC_Forum_Feature Request.jpg / V - Attached On 2022-11-16 22:21:46 UTC - Size: 84.41 KB - 158 views
