Date/Time: Thu, 20 Mar 2025 19:55:56 +0000
sharing SC/Data
View Count: 363
[2022-11-16 20:17:57] |
User531621 - Posts: 109 |
Hello! Is it possible to let my son piggyback off my SC and Rithmic data feed? His account is 123732 Just trying to save him monthly fees. And if so, please let me know how to set that up. Thank you so much!!! |
[2022-11-16 22:37:44] |
John - SC Support - Posts: 38831 |
Officially, our policy is that each person is supposed to have their own Sierra Chart account. Refer to our Licensing information here: Sierra Chart Purchase and License Information: Licensing / Number of Systems But, this is not something we check on, so if it were to occur where you had your son setup with his own installation of Sierra Chart (either on the same computer or on a separate computer) and he was running the software, then we would not bother you about it. But, since you are looking to get data from Rithmic, you will probably have an issue in getting the data to two different places at the same time (assuming you are both running Sierra Chart at the same time). Otherwise, if you are logging in at different times, then this may not be an issue for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
