Date/Time: Thu, 20 Mar 2025 20:00:58 +0000
Premarket lows and highs
View Count: 391
[2022-11-16 15:26:29] |
User678193 - Posts: 12 |
How can i have premarket lows and highs automatically plotted? How can i set this up?
[2022-11-16 17:45:51] |
John - SC Support - Posts: 38831 |
How you do it depends on what exactly you want to see and how your charts are setup. Please answer the following questions and we can then point you in the right direction: - Are you wanting the Low and High for the entire overnight session or just a certain period of time? What is the time frame you want to cover? - Is the chart that this is going to be displayed on have the Session Times that cover the time period for which you want the High and Low? Or is this on a separate chart? - How do you want to display the High and Low from the Pre-Market - Do you want it displayed on the Regular Trading Hours for that day? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
