Date/Time: Mon, 21 Sep 2026 09:41:56 +0000
Alert notifications & N period still not right
View Count: 873
[2022-11-16 00:37:48]
User72965 - Posts: 116
How do I enable the Trade Alerts? There is 6 of them??
N is running 1 minute over the 14:00:00 ???
I tried moving it 1 minute;to no avail ??
It should go on 14:000:000 Makes a false <> False over night
Gene:)
https://www.sierrachart.com/image.php?Image=1668559020236.png
[2022-11-16 15:12:07]
John - SC Support - Posts: 47939
You go to the Trade >> General Trade Settings >> Notifications and select the Alert number for the trade alerts you want to receive. Refer to the information starting at the following:
Global Trade Settings Windows: Play Alert For New Order (Global Settings >> General Trade Settings >> Notifications)
We are not understanding this. We see the overnight TPO which starts at 14:00:00 and has the first period using the letter N, but what do you mean it is running over 1 minute?
[2022-11-16 16:47:08]
What's happening is > 14:00:00 to >>>>> 14:00:01
maybe it should be 14:01:00 to represent 1 minute ~~~
= It's putting N in the current day NOT into the Over Night...
Keeping it in the day time frame~ @ 14:01:00 1 minute it then
changes over to after hour trade~~ Leaving the 1 minute in the
day session. It may be in the OHLC Study ???
Thx Gene :) Deal with the Alerts after we get Over Night Oked :)
[2022-11-16 18:53:56]
Please check the Input for the TPO Letter Sequence for the TPO study and ensure that there are not two N's in the sequence (i.e. do you have the following LMNNOP).
[2022-11-17 15:31:47]
Please get us the chartbook that has this setup in it so we can take a look. Follow these instructions:
