Date/Time: Sun, 04 Oct 2026 17:55:49 +0000
IB symbol update erased my chart drawings
View Count: 728
| [2022-11-15 19:17:18] |
| luckystripes - Posts: 2 |
I followed the IB update steps for ES but it cleared all my chart drawings. Luckily I still have my old ES chartbook with drawings. How can I move my old drawings to the updated ES chartbook?
| [2022-11-15 21:34:54] |
| John - SC Support - Posts: 48095 |
Did you Duplicate the charts from the old chartbook to the new one and then update the symbols? If so, then the drawings are still there, just not visible since the symbol changed. If the above is the case then refer to the following: Chart Drawing Tools: Showing or Hiding Drawings for Different Symbols If you did something else, then we need to know how you created the new chartbook. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-16 05:09:51] |
Didnt realize I had to check show drawing for different symbol. That fixed it for me. Thanks.
