Date/Time: Sun, 13 Sep 2026 17:42:30 +0000
Question about multiple instances
View Count: 607
| [2022-11-15 16:54:52] |
| User397331 - Posts: 15 |
Am I correct that I can install 2 copies of Sierra in 2 different folders on the same computer and have both copies running at the same time on different monitors in real time? One using Danali data and CQG order entry with AMP and second using Danali data and Teton order entry with Ironbeam with one subscription? Also if I install on 2 different computers and run at the same time I need and pay for a second subscription to Danali and exchange fees? Thanks |
| [2022-11-15 17:34:53] |
| John - SC Support - Posts: 47854 |
Yes, you can have Sierra Chart installed as many times as you like on the same computer. You can also have up to 3 separate installations getting data at the same time from the Denali Exchange Data Feed (there are different rules for the software versus the data since the exchanges have their own way of doing things). With regards to two separate computers we just want to make sure that you understand that you only need to pay a second exchange fee. Refer to the information for the Denali Exchange Data Feed and connections at the following link: Denali Exchange Data Feed: Connections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
