Date/Time: Fri, 21 Mar 2025 07:38:55 +0000
missing icons from tool bar
View Count: 454
[2022-11-15 13:26:09] |
User427561 - Posts: 217 |
The horizontal, vertical and ray icons disappeared from the toolbar. how do I restore them ?or modify that tool bar?
Date Time Of Last Edit: 2022-11-16 20:41:42
[2022-11-17 14:31:14] |
still need guidance on how to add drawing icons to control bar thanks
[2022-11-17 17:47:12] |
John - SC Support - Posts: 38835 |
To setup the Control Bar buttons for the Drawing Tools, refer to the following: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step If a particular control bar is not displaying, then refer to the following: Control Bar: Window >> Control Bars >> Control Bar [1-12] For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
