Date/Time: Thu, 05 Nov 2026 06:12:51 +0000
Number Bars, Column 1 Text Coloring Method, Based on Separate AskVol BidVol Percentage
View Count: 731
| [2022-11-15 05:55:02] |
| User223498 - Posts: 10 |
The color for the Ask text always appears as Range 3 Color regardless of 'Column 1 Percentage Compare Threshold value'. Bid Text color appears correct and changes with 'Column 1 Percentage Compare Threshold value' setting. Am I missing a setting somewhere that is preventing the ask text color from changing properly?
| Attachment Deleted. |
| [2022-11-15 16:00:13] |
| John - SC Support - Posts: 48431 |
Please get us a copy of that chart so we can take a look at how you have it setup. There are just too many options with the Numbers Bars to try and go through them all through this forum. Refer to the following for how to get us the one chart in a Chartbook: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-15 22:38:18] |
Chartbook attached. Thanks!
| [2022-11-15 23:34:10] |
We found the issue and have fixed it. It will be in the next Pre-Release (v 2454). When available you can update to this release using these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
