Date/Time: Fri, 21 Mar 2025 07:57:06 +0000
Order confirmations
View Count: 477
[2022-11-14 20:22:54] |
User634501 - Posts: 14 |
Despite I have disabled any order confirmations in the Trade Window>M>Confirmations menu, I still get prompted every time I send an order. I tried to follow other instructions in the forum (e.g. choosing Yes in Chart Settings>Linking>Chart Linking>Trade Window) without any luck. Any advice please? Thanks |
[2022-11-14 20:50:21] |
Sierra_Chart Engineering - Posts: 18875 |
Make sure you are disabling the confirmations on the correct Trade Window: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-15 07:33:53] |
I followed all the instructions (reset child window, check the trade window link etc...), however I'm still getting the same confirmation message. Any other suggestions? Thanks |
[2022-11-15 11:59:42] |
It must be related to the confirmation options. We have to check this. Provide us the chart you are trading from by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-15 12:00:07
[2022-11-15 15:31:50] |
Here you go. Thanks
Attachment Deleted. Private File |
[2022-11-15 20:38:47] |
We need to know the Chart Number you are trading from? Chart Numbers will be seen on the title bar of the chart and are followed by a #. We will then look at that particular Trade Window.
[2022-11-16 07:55:36] |
It's #12 (Chart window named 'IDTrigger'). Thanks
[2022-11-16 16:54:53] |
We do not see any confirmation come up when trading from that chart. What exact action are you performing that is causing the confirmation?
[2022-11-16 17:13:18] |
I attached the screenshot of the window. To answer to you, whenever I click any buy/sell button in the Trade Window. Thanks
[2022-11-17 15:53:06] |
We tested that chart, and there are no confirmations using those order entry buttons.
[2022-11-17 16:10:59] |
I think I've sorted out. Apparently the message came because the option 'chart trade mode on' was activated in some hidden windows. Disabling the 'chart trade mode on' in one of them fixed the problem. Thanks |
[2022-11-18 02:23:43] |
We do not see how that setting would have any relevance to a confirmation. It does not.
