Date/Time: Thu, 20 Mar 2025 20:03:31 +0000
Trade activity log
View Count: 547
[2022-11-14 19:44:11]
Steve Leon - Posts: 312
Is there a way to display only certain columns in the trade activity log ?
For example if I want remove the order ID column or the trade account number can that be done and how ?
Thank you
[2022-11-14 20:46:08]
Sierra_Chart Engineering - Posts: 18860
The only way this can be done is to narrow the columns you do not want to see and then drag them over towards the right. This is all possible by left clicking and dragging in the header area of the Trade Activity tab.
Date Time Of Last Edit: 2022-11-14 20:46:20
[2022-11-15 22:19:24]
Thank you I was able to do what you described.
Is there a way to create a spreadsheet study from the Trade activity Log and/or Trade Activity Statistics ? or some way to capture the data that is present in those studies and export it/manipulate it ?
Thank you
[2022-11-15 23:09:18]
John - SC Support - Posts: 38831
The data can be saved or exported (they give slightly different information). Refer to the information starting at the following link for these options:
Trade Activity Log: File >> Save Log As
[2022-11-16 01:12:58]
Thank you I was able to save and create a spreadsheet for Trade Activity Log and Statistics
Is there a way to export this information to Excel in this format ?
Can you give me some advice as to where i could find some information on examples of how to use the information from the spreadsheet to some applications that would demonstrate how to use some of the functions ?
I dont know if it would be better to work with the data within Sierra or export it to Excel ?
I am interested in developing a custom display of the data.
Thank you
[2022-11-16 15:17:39]
Either format of the save/exported Trade Activity Log could be imported into Excel. They are straightforward tab-delimited data.
We are not sure what you are asking for here.
