Date/Time: Tue, 26 Nov 2024 20:21:21 +0000
New request for the Horizontal Line by UseTool
View Count: 1336
[2014-05-24 15:38:39]
sampater - Posts: 244
At first i would like to thanks for every implements that you have done for Chart Drawings by UseTool.
Could you please implement to set alignment the date/time for the DRAWING_VERTICALLINE in a way, that the date/time is displayed on a bottom of the Main Region, and not on the bottom of all Chart when is used TextAlignment = DT_BOTTOM.
Now, i have indicators which are displayed on the top of main region and on the bottom all chart. In this case if i want to display any date/time for the Horizontal Line, then the date/time obscured this indicators.
Thank you very much,
Marek
[2014-06-06 09:56:20]
Sierra Chart,
Could you please refer to my request?
Thanks,
Marek
[2014-06-06 16:48:06]
The only way we would do this is to add an option to the Vertical Line study to make it draw only within a specific Chart Region or across all chart regions.
[2014-06-06 21:05:50]
It is the very good solution for me, if i could drawing this Vertical Line by the sc.UseTool in the ASCIL.
Thanks,
Marek
[2014-06-06 21:47:08]
Yes, this will be possible.
[2014-06-06 23:54:31]
Thank you very much !
[2014-06-18 09:24:03]
Sierra Chart,
Did you already implement this feature?
Marek
