Date/Time: Wed, 23 Apr 2025 03:24:09 +0000
Mobile Version
View Count: 1861
[2022-11-11 17:21:01] |
User562957 - Posts: 58 |
Hello Support Team, I wanted to trade live next month. if i have internet problems or i can't access my computer i wanted to ask what possibilities there are to close positions if you don't have internet access. For example, is there a mobile version that I can reach with my cell phone, because I always have internet with my cell phone, or what additional options are there? |
[2022-11-11 18:10:53] |
Tony - Posts: 565 |
You could also set cellphone's hot spot (act as a wireless router)
[2022-11-11 19:31:24] |
John - SC Support - Posts: 39428 |
If you are using our Teton Order Routing Service, then we have a Web-Enabled option available. Refer to the following: Sierra Chart Teton Futures Order Routing: Web-Based Trading Panel Other order routing services have options - you would need to ask your broker about what is available. Also, you can always call your broker to close a position for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-02 21:59:53] |
TonyCipriani - Posts: 27 |
Hello, Is it possible to adjust an existing stop loss order to change where it is placed on the web panel? From the looks of it, I think it's only meant for creating new orders and exiting positions. Thank you |
[2024-07-02 22:54:12] |
Sierra_Chart Engineering - Posts: 19307 |
No but we can add modify capability. We will make a note to do this.
[2024-07-03 20:56:58] |
Order modification capability is being added to the new web trading panel.
[2024-12-06 17:27:10] |
Hello, It was said on the "What is Sierra Chart Working On" thread (post #97) that the web trading panel was being added for modification capability. I was just wondering if https://apps.sierrachart.com/tradepanel/ is ready to adjust our orders. Thank you so much. |
[2024-12-10 00:27:32] |
We are checking on this.
[2024-12-10 17:02:33] |
frozentundra - Posts: 94 |
@TonyCipriana - modify order capability is live on the new Web Trading Panel at the URL you listed: https://apps.sierrachart.com/tradepanel/
[2024-12-11 03:35:16] |
Thank you @FrozenTundra! I was using the old web panel because on the bottom of the page of https://www.sierrachart.com/UserControlPanel.php it links to the old one. However, the link on Sierra Chart Teton Futures Order Routing: Web-Based Trading Panel does show the new one too. I wasn't sure if it was ready but it looks like it is. Thank you SC team! |
[2024-12-11 05:56:13] |
Yes, the new web trading panel is ready for primary use. And we have updated the links.
