Date/Time: Thu, 20 Mar 2025 09:08:31 +0000
Adding months to Daily&Weeks Danali&Teton
View Count: 336
[2022-11-10 16:39:53] |
User72965 - Posts: 115 |
Where do I go to Add months to an intraday chart?? What do I need to do with Danali&Teton?? {due 11-18} Do I need them & Extra Cost?? Thx Gene :) |
[2022-11-10 18:10:44] |
John - SC Support - Posts: 38812 |
To add more time to a chart go to Chart >> Chart Settings >> Data Limiting and change either the Days to Load for Intraday Chart Data Type or the Date Range From/Date Range to depending on which of these is being used for the specific chart. Refer to the following: Chart Settings: Days to Load for Historical Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Days to Load menu) Denali is our real-time data feed. You are using it for your real-time data from the CME exchange (just the CME, not all four exchanges that make up the CME Group). Refer to the information at the following link: Teton is our Order Routing service that gives brokers an alternative for order routing where we do not charge any fees for order routing. Refer to the information at the following link: Sierra Chart Teton Futures Order Routing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
