Date/Time: Thu, 19 Sep 2024 21:41:24 +0000
Reversal doesn´t work with Trading Window, help!
View Count: 1119
[2014-05-23 21:30:59] |
User84572 - Posts: 2 |
Hi Guys, I am creating a system with the spreadsheets and simple moving crossing as below, but the reversal is not working everytime that a try to autotrade replay backtest system, the parameters for reversal turned to false??? Any idea? help? what is wrong? |Formulas =IF(AND(AA62<AB62;AA61>AB62);TRUE) =IF(AND(AA56>AB56;AA55<AB55);TRUE) Parameters Below Connected to Data Feed (read-only): FALSE Reset Condition On New Bar (read-only): FALSE Allow Multiple Entries in Same Direction (read-only): FALSE Signal Only Once Per Bar (read-only): FALSE Cancel All Orders on Entries and Reversals (read-only): TRUE Allow Entry With Working Orders (read-only): TRUE Signal Only On Bar Close (Columns L, N-Z) (read-only): FALSE Signal Only On Bar Close (Columns K, M) (read-only): FALSE Maximum Position Allowed (read-only): 1000 Send Orders To Trade Service (read-only): FALSE Support Reversals (read-only): TRUE Allow Opposite Entry with Opposing Position or Orders (read-only): TRUE Cancel All Working Orders on Exit (read-only): FALSE |
[2014-05-26 07:45:25] |
The problem with Reversals is that if the reversal condition has not been met, there is no logging of that case and the reason for that, because there are many conditions to support a reversal. We can only refer you to the documentation here for Support Reversals: http://www.sierrachart.com/index.php?l=doc/doc_AutoTradeManagment.php#SupportReversals Are you using Attached Orders with your trading system? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-26 07:45:51
[2014-05-27 12:35:33] |
Thanks for the answer! I think the problem is with the attached orders. Looks like, when i used attached orders the system doesn´t allow reversals. Any idea ? do i need to have a diferent setup to use attached orders? Regards Teodoro |
[2014-05-28 08:23:33] |
Attached Orders do add a another layer of complexity to this. Although this should allow you to use attached orders: Cancel All Orders on Entries and Reversals (read-only): TRUE Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-30 10:26:34] |
In the next release, we are going to be adding logging to indicate when a reversal signal is ignored when there is already an opposing Trade Position relative to the new order side.
