Date/Time: Thu, 20 Mar 2025 07:10:14 +0000
Urgent: Compile issue between V.2280 and V.2451
View Count: 449
[2022-11-09 17:54:59]
User92573 - Posts: 552
Dear Support
I have 2 .cpp ACSIL files which compile to dll's without issue on both V.2280 and the current V.2451
However, the dll's compiled using "Build with VC++ Release" in the current V.2451 nolonger run.
Those recompiled again using the older V.2280 once more run without issue.
Please would you advise me of what needs to be added or changed in the compiler, file layout or header of .cpp to solve for the changes.
Many thanks.
[2022-11-09 18:44:00]
Dear Support
The error came from the default selection of compiler in the newer version of Sierra Chart.
For example:
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Auxiliary\Build
I've updated this to:
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC
But please provide settings if the newer VS 2019 is now the preferred compiler?
Many thanks
Date Time Of Last Edit: 2022-11-10 10:26:39
