Date/Time: Thu, 20 Mar 2025 07:13:25 +0000
vbP chart display error, see attach photo
View Count: 469
[2022-11-09 12:56:14] |
User686802 - Posts: 69 |
Hi, i am on v2451. Please see attached photo of VbP chart setting. I marked Green as good with the correct spacing and Red as bad with the lack of spacing in the graph.
[2022-11-09 17:26:42] |
John - SC Support - Posts: 38812 |
We have set this as a Feature Request. Just keep in mind that we can not say when, or if, we will get to any particular feature.
[2022-11-09 17:58:04] |
Well the Top settings works with correct spacing and the Bottom settings is clearly unusable. Please make it a display bug, how can you look at the picture and say it is not a display bug and it is a NOT a feature request.
[2022-11-09 18:24:36] |
The only issue we see is with respect to the number 12 that is in the display. That is not coming from the VbP, it is there from something else. It is that number that makes those lower numbers difficult to read, not the proximity to the profile.
