Date/Time: Thu, 20 Mar 2025 07:19:41 +0000
Bid x Ask Vol missing on VbP when one side is 5 or less
View Count: 491
[2022-11-09 00:46:18] |
dvant krypto - Posts: 43 |
Hi, In the attached screenshot, I have a VbP study on the left - it is set to show Bid x Ask and the nodes are set to show Delta rather than volume. Is you look at the last node it should show 78 x 4 but it is blank. The issue is the same whether I have Delta or Volume nodes with Bid x Ask setting. |
[2022-11-09 14:46:09] |
John - SC Support - Posts: 38812 |
Please get us a chartbook containing that chart so we can take a look at it. Follow these instructions to get us the chartbook: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-09 17:27:00] |
Chart with only the relevant study attached.
Private File |
[2022-11-09 18:05:02] |
You have the Input for Volume Text Threshold set to 6. This is causing the low value bars to not display. Change this to 0 to have everything show up. Refer to the following: Volume By Price Study: Volume Text Threshold For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
