Date/Time: Thu, 20 Mar 2025 06:58:57 +0000
Mouse functionality
View Count: 623
[2022-11-07 17:45:27] |
User148596 - Posts: 217 |
Hi, I was wondering if there's any way to map different buttons and scroll wheels on my mouse for different functions. Currently the main scroll wheel moves scrolls the chart forward or backward in time. I have a thumb scroll wheel on my mouse as well that I would love to be able to adjust the chart range with. Is this something that is possible or that there might be any interest in adding? I find that I'm constantly having to bring up the scale range menu and switch it from adjust range to move range based on what I'm looking at. It's a bit cumbersome and seems like being able to map those functions to my mouse would be the best solution. Thanks |
[2022-11-08 15:42:53] |
John - SC Support - Posts: 38812 |
There is a setting for the Scroll Wheel functionality. The other buttons are not programmable within Sierra Chart. Refer to the following: General Settings Window: Scroll Wheel Setting (Global Settings >> General Settings >> GUI >> Scroll) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-09 15:53:23] |
Okay thanks, no options for adjusting the price scale but at least I can scroll on the vertical access now so that's a plus. Thanks
