Date/Time: Sat, 11 May 2024 16:54:37 +0000
charting
View Count: 1642
[2013-04-30 13:07:17] |
User39772 - Posts: 311 |
Hello, I use a Daily chart (historical) for e-mini and intraday charts. Before the market opens I see intradayactivity on the daily chart but I want daily charts with opening price @ 9:30 and clo ing price @ 16:00 CET. what can I do ? |
[2013-04-30 18:14:47] |
Refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails13.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-02 12:07:50] |
Hello, if I change to Intraday only ans set 1-0-0 I see daly chart but not as much bars a in a historical chart. I want to see > 300 days of historical bars but only see 30. The problem mentioned above does only seem to exist in connection with the mini futures. When I chart stocks on a historical chart I have as much bars available as I want and only see the trading hours. What do I have to do to get the same results with the minis. |
[2013-05-02 16:23:19] |
Please follow the instructions in help topic 42.1 : Http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-02 16:23:45
