Date/Time: Tue, 26 Nov 2024 15:29:38 +0000
Data feed
View Count: 1295
[2014-05-23 13:21:53] |
User60579 - Posts: 41 |
Hi there Is it possible to use Sierra Chart with the Bodigold data feed? http://www.justdata.com.au/Products/BodhiFreeway/bg_charting.htm Cheers |
[2014-05-23 16:37:27] |
If it provides data in a text format, then it can be used. Here is the documentation for the Sierra Chart Text/CSV format: http://www.sierrachart.com/index.php?l=doc/doc_TextCSVDataFormat.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
