Date/Time: Tue, 26 Nov 2024 15:22:39 +0000
Periodic Alert Study?
View Count: 1077
[2014-05-22 22:20:29] |
User51760 - Posts: 108 |
Hello Support Team, is there a study providing a periodic alert sound every 10 minutes? Thank you for your support, Chris |
[2014-05-23 03:31:45] |
Something like this would have to be custom programmed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-23 03:31:55
[2014-05-23 06:12:27] |
Sawtooth - Posts: 4120 |
You could add a 10 min chart to your chartbook and then add the Countdown Timer study, and set 'Alert On New Bar' to Yes.
[2014-05-23 06:41:30] |
This is a good idea.
[2014-05-23 09:59:30] |
Hello Support, thank you for your reply - this is a great and spirited support board. @ tomgilb, hello and thank you so much for the great suggestion. Best, Chris |
