Date/Time: Mon, 21 Apr 2025 13:14:34 +0000
Realtime data for transact users?
View Count: 714
[2022-11-02 17:47:53] |
User925138 - Posts: 24 |
I am paying for Denali. I am a transact user which is now Ninja Trader. How can I get realtime data? |
[2022-11-02 20:18:41] |
John - SC Support - Posts: 39362 |
TransAct stopped support for Sierra Chat several months ago. You were continuing to get the real-time data from our Denali data feed as your non-professional verification was valid through October 31, 2022. Since we are now passed that date, your verification is no longer valid and you are not able to get the real-time data, therefore you are getting the Delayed Streaming data instead. If you want to continue to use Sierra Chart for trading, then you will need to change brokers. We recommend a broker that supports our Teton Order Routing Service. You will find the list of brokers that support this service at Step #2 of the Setup Instructions for the Teton Order Routing Service here: Sierra Chart Teton Futures Order Routing: Setup Instructions If you want to use Sierra Chart just for charting, then you will still need to have a trading account you can use to verify your non-professional status for the CME Group. We recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-03 06:24:41] |
Sierra_Chart Engineering - Posts: 19285 |
We will follow-up with you today regarding accessing real-time data. .
[2022-11-03 15:08:11] |
SC Support - Posts: 1954 |
Spoke to User925138 about set-up.
[2023-07-07 16:46:34] |
I seem to have current data for the ES and NQ but not the YM? I don't want Denali on the YM. Just the basic for that market. I have Denali for the ES and NQ and want to keep that for them. Thanks for your time and help! -Kevin |
[2023-07-07 17:01:51] |
Ok, so you have what you want Kevin? You don't want YM and you don't have it (YM is a CBOT instrument, unlike the others)
[2023-07-07 17:04:15] |
I want to trade the YM but there is a delay in my charts and dom Currently, the YM is at 34227 but my dom is showing 34199. Thanks again, -Kevin |
[2023-07-07 17:10:14] |
I did update to the current version, but that didn't fix it. Thanks, -Kevin |
[2023-07-07 17:18:31] |
I don't want Denali on the YM. Just the basic for that market. >> Do you mean that you want Top of Book Data? and when you say "Denali" you are talking about Market Depth Data? You can activate the Real-time Top-of-Book Data for CBOT via #3 here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME Date Time Of Last Edit: 2023-07-07 17:22:00
[2023-07-07 17:21:23] |
I want Real-Time but I don't need Denali on the YM. -Kevin |
[2023-07-07 17:24:13] |
The 'CBOT non-professional top-of-book' exchange has been internally activated, and will be renewed. This change will go in effect in approximately 3 minutes. If it does not, then restart Sierra Chart after that time. Activating CBOT non-professional top-of-book. You must have a funded futures Trading account with one of the supported Trading Services and Sierra Chart must be connected to that account, to be able to use this exchange. Do *not* activate this exchange unless you have a funded futures trading account with one of the supported Trading Services because otherwise you will not receive real-time data with this particular exchange and Sierra Chart support will not be able to issue a refund. You will be charged 1.25 USD for the real-time data from the CBOT non-professional top-of-book exchange from this moment until July 31. You will be charged the 1.25 USD next month on August 1 unless you deactivate the exchange. |
[2023-07-07 17:42:15] |
Thanks! YM looks like real-time now. -Kevin |
[2025-03-03 15:12:37] |
I missed a payment and my Sierra expired. I paid yesterday, but I'm receiving delayed data. What do I need to do to get real-time data again? I clicked on the activate Denali. Thanks for your help and time. -Kevin Kiernan |
[2025-03-03 15:35:03] |
Hi there, please activate the CME Group Exchanges that you want Real-time Data for, you can do that via #3 here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME Then please re-connect to the Data Feed: File Menu: Connect to Data Feed (File) |
[2025-03-03 15:39:11] |
Looks like I reactivated the correct ones. Thanks! -Kevin |
[2025-03-03 16:39:08] |
Thank you
