Date/Time: Sat, 30 Nov 2024 02:48:56 +0000
[Programming Help] - HOWTO TURN on-off AT via acsil ?
View Count: 540
[2022-11-02 15:37:28]
User574685 - Posts: 28
Hi
is there a function or some possibility to turn on/off AT (autotrading) by acsil ?
Thanks for help
Dave
[2022-11-02 16:42:56]
JohnR - User831573 - Posts: 306
This might be what you are looking for.
ACSIL Interface Members - Variables and Arrays: sc.TradingIsLocked
sc.TradingIsLocked
Type: Read-only integer variable.
The sc.TradingIsLocked variable is set to 1 when Trade >> Trading Locked is enabled. Otherwise, it is set to 0.
To change the state of trading locked, use the sc.SetTradingLockState function.
Hope this helps,
JohnR
[2022-11-04 21:10:33]
ForgivingComputers.com - Posts: 960
Locking trading will also lock manual trades, and lock trading on all charts. An alternative would be:
sc.SendOrdersToTradeService = false;
[2022-11-07 21:42:14]
User90125 - Posts: 715
Support,
Is there an available Control Bar command for this? If not, can one be added easily?
Thanks.
Date Time Of Last Edit: 2022-11-07 21:46:23
[2022-12-26 21:02:27]
Just following up on this.
If it were to be added, could it be done on a per-chart only basis.
The current Trading Locked control bar seems to lock up everything on a universal basis.
[2022-12-26 21:44:44]
You can add a Control Bar Button for Trade>>AutoTrade Enabled - Chart
[2022-12-27 00:03:26]
ondafringe - Posts: 286
You can put your trade execution code inside a conditional statement. Then create a bool variable, and setup a hotkey to turn that variable on/off.
I do that and have a bool for pause trading. I press "P" to pause trading and press "R" to resume trading.
