Date/Time: Wed, 19 Mar 2025 19:37:29 +0000
Chart Question
View Count: 358
[2022-11-01 19:29:32] |
User367155 - Posts: 7 |
Hello, I do not want to post this question in the support board because the template is private. My question is that, I opened a new chart in sierra chart. But it looks like the chart is stuck within the main template. How can I make it pop out like the chart in front? Screenshot attached. Note: I need to be able to move it anywhere like the white chart in front of the screenshot. Let me know if you need more details. |
[2022-11-01 21:36:38] |
John - SC Support - Posts: 38806 |
It sounds like what you want to do is to "Detach" the chart from the main program. Refer to the following: Window, CB and CW Menus: Detach/Attach Window (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
