Date/Time: Wed, 19 Mar 2025 19:33:46 +0000
Eurex routing
View Count: 346
[2022-11-01 19:02:15]
User343060 - Posts: 7
it seems that the Teton routing is not available for Eurex right ?
So how is it possible to trade the Eurex without it ? (Without using IB as a broker) Is it possible to use the Denali data feed and cqg for order routing for example ?
[2022-11-01 19:02:58]
Or maybe rithmic ?
[2022-11-01 21:28:01]
John - SC Support - Posts: 38806
You are correct, the Teton Order Routing is only for the CME Group and does not have support for EUREX.
What we recommend is opening an account with Stage 5 or Edge Clear and have that account setup for the Teton Order Routing Service to trade the CME Group and then have them setup another account with CQG in order to trade the EUREX.
If you go this route, you will want to have two different installations of Sierra Chart in order to have one connected to the Teton Order Routing Service and the other connected to CQG. Refer to the following for how to install a second Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
The Setup Instructions for the Teton Order Routing Service are at the following link:
Sierra Chart Teton Futures Order Routing: Setup Instructions
The Setup Instructions for CQG are at the following link:
CQG Trading Platform Service: Setup Instructions
In both cases above you will use the Denali Exchange Data Feed for your data (from both CME Group and EUREX). Refer to the information at the following link (note the Setup Instructions on this page):
