Date/Time: Wed, 19 Mar 2025 19:27:48 +0000
Candlestick Distance
View Count: 315
[2022-11-01 09:17:28]
User367155 - Posts: 7
Hello, screenshot attached. You will see from the screenshot the the distance of the candles from the right side volume profile is too far. When I am trying to back track candlesticks history, the distance from the volume profile and the candlestick is kept on the same distance. The space created is being wasted. I need to somehow shorten the distance of the volume profile to the candlesticks so that I can view more candles.
Screenshot private.
Thank you.
Private File
[2022-11-01 14:59:08]
John - SC Support - Posts: 38806
If you can not move the bars further to the right, then this would mean that you have the "Lock Fill Space" option enabled. Refer to the following:
Chart Menu: Lock Fill Space (Chart menu)
